Dare I ask what the best way of removing this is? I tend to replace the fuel filter when I replace the oil filter anyway (i.e every 5k kms), because it's .. right there, and costs like $10.
I've only cleaned the pump out, but never really attempted to cut the mesh.
I used a new stanley knife blade
Not easy but I made it
Work
Could use anything really
so im going to replace it AGAIN with something different, just for funzies. anyway obviosuly my tank still has shit in it.
i could get the tan kcleaned and try again but i am sick of going through pumps. i do not know if its just debris in the tank or if its rust from the old tank.
You are sick of going through pumps.
But don't want to get the tank cleaned.
I'm confused, the pump wouldn't block up if the tank/lines were cleaned correctly...
No, the sock flaps around and shakes the crud off. That's the whole point of a floppy filter.
I did not know this. This is good. This will have to go on too. Thankyou for the info!
I should also say (though the above reply is not to me) that cleaning the tank and solving the issue is absolutely the best way to attack this. If the job to remove a tank in a 32 or 33 really is a 10-15 minute job then don't think about doing anything else. The R34 tank in my case to remove and put back on is a 8hour+ job which is why I'm willing to entertain alternative solutions! :P
no, if their was rust then the tank would be replaced, their wasnt so the tank was cleaned, new pump, all is sweet.
I removed the mesh on 040 worked well for me
No issues I did a filter on every service
5000kms
Just comes down to what your prepared to do
I cut mine off as I got sick of pulling pump to clean it.
wtf??
This is like saying "my fuse kept blowing so I replaced it with a nail" or "my computer kept crashing so i threw it out the window"
Now all that shit that was clogging your pump filter is INSIDE YOUR PUMP/LINES AND f**kING THEM INTERNALLY.
Seriously. It is an utter bastard on the R34. So much so I'd almost rather spend $1200 on fuel pumps lol. I'll try the filter and jerry can thing and post here just incase some poor soul has this problem and searches the forums and finds this (like I did)
i believe the car in question is a r32 not a 34?if he cleans/reuses his existing tank then everything will fit back up as intended
Why doesn't everyone just fit a decent sock to the pump? It's not real hard. I have the original sock attached to an 040 in R32.
How the hell can u attach the stock filter to the gauze on the bottom of the 040?
yeah was an r32, i got away with cleaning the fuel tank, replacing the pump and filters,
my mesh filter on my bosh 040 was clogged an the fuel pump was f**ked out. i was hoping to clean it off enough to drive a bit but just changed everything anyway.
dunno what people are removing filters for?
having dealt with a grunged up tank (car had stale fuel that had broken down over time)i believe the only way to clean it is to remove the tank, hit it with caustic soda and then a karsher high pressure water cleaner , i then flushed the fuel lines with solvent and chucked everything back together,(injector cleaner added) used a known working replacement fuel pump as the original was seized up with crud and couldnt be unseized, having seen the crap in the tank there was no way i was going to run the fuel pump without the strainer
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
