We've just fitted the EVC 4, and have a few problems....
1. If I set the High Boost to say 1.1bar, the boost reading goes upto 1.2-1.3, but on the dyno the boost is holding spot on.
2. Had a mate look at the instructions, and he thinks the LOW boost setting is when the controller starts to open the wastegate for spooling & the HIGH boost setting is the limit of boost. I thought he was crazy, because as I understand it, the LOW boost is for lazy driving & the HIGH boost is for everyday driving. But after some testing, I think he is correct, maybe someone can test it themselves? When I set my LOW Boost to eg: .5 and HIGH to 1.1 the boost comes on smooth and early, if I set my LOW boost equal to my HIGH boost, the boost is much more agressive and comes on later.
I'm running HKS Silver Actuators which I believe are .9 ~ 1bar, If I'm setting my EBC LOW Setting below this figure, is it useless having these actuators?
https://www.sau.com.au/forums/topic/40217-whos-using-hks-evc-boost-controller/
from the experience i have with mine
i used to have my low boost set at .5 bar and high of .75 bar and it seemed correct according to the boost guage
thats how it worked for me so thats my understanding of it
Your mate is incorrect.
EVC has two boost settings, hi and low. Their adjustments do not have any effect on how the boost comes on and judging it by the seat of the pants can be misleading.
If you have 1 bar actuators, you can't set the low boost below that. Simply, the boost controller can not hold boost at 0.5 bar, if your wastegates don't open tilll 1 bar.
So, set your low boost at minimum 1 bar and high boost to whatever the car has been tuned to on pump fuel. If it isn't holding boost correctly it can be fined tuned with the offset feature. FWIW, mine is set at 1.40 bar and never gets touched, would you set your rev-limiter at 6000 rpm...?
The best way to monitor your boost levels is on the dyno, as the peak hold values shown on the hand controller doesn't mean much. Saying that it's common for an EBC to behave differently on the road compared to the dyno, if a high ramp rate have been used.
  • 1 month later...
Just thought I update this thread...
My problem is all fixed now.. turned out the evc needed a RESET & LEARNING MODE run. I basiclly followed the instructions as detailed in the EVC setup manual. The boost now holds/reads perfectly, and the OFFSET mode setting is spot on 100 where it should be.
After the RESET & LEARNING MODE runs, I also turned off the AUTO ADJUST setting as specified in the manual which it recommends to do, simply by: Turn the Ignition to ON, holding the MOD button, flick the SW-PO switch > wait for the beep (still holding te MOD button) then return it SW-PO to it's original position and you should hear another beep.
So if anyone is having issue with boost readings going over the set boost levels, and you cannot adjust your OFFSET any more (eg: 50 or 150 - like me) just do the above or refer to the manual.
Does anyone have an evc 4 pdf manual ???? or know where to get one ...
i have an evc 4 sitting in a box, waiting to be fitted as soon as I move into my new abode, and get to unpack all the boxes ..
and i'll be buggered if I can remember how to install it. had it in my mr2 turbo first, then pulsar gti-r, now the skyline ... rar
also ,i have not taken delivery of the car yet ...
i managed to get a grade 3.5 gtst s2, in solid red ... a rare colour as far as I can tell ...
anyway, if anyone does have a manual, can you forward it to :
[email protected]
Thanks very much ...
When you first install the evc you have to let it learn your actuator. go for a drive, put it in 3rd and from 2000rpm floor it to redline. Then tune it from there. I have the ricey EVC5 and its a really good controller imho.
-rb25
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
