Gun Metal Grey 1990 GTR
Engine - RB26 With Variable inlet Camshaft
Standard Rebuild with R33 GTR Crank
ERD Oil pump gear set
Rings/bearings etc.
ARP Rod bolts
Oil restrictor in block
Stainless exhaust valves
ERD Variable Cam timing (like HKS VCam)
Super tech Valve springs
[email protected] Exhaust Cam
ERD RB26 Billet VCT inlet cam
Ross Balancer
Manual adjustable gear on exhaust cam
CRG Merge collector Steam pipe manifold with EGT ports
Plain Bearing T04Z with 0.64 T4 exhaust housing
44mm External wastegate off exhaust housing
4 inch exhaust with 3.5 inch resonator
110mm Intercooler
HKS hard piping kit
Koyo Radiator
Custom Oil Air seperator
Fuel System -
Delphi feed pump
3 Ltr Surge Tank
2 x Piburg fuel pumps (13.5 liters a min)
HKS Fuel rail
RC 1200cc Injectors
FAST Fuel regulator
LS2 Coils with custom leads
Wolf V550 ECU with wide band feedback
2 Step Setup
Excedy twin plate clutch Rebuilt (by NPC)
Wheels/Tyres - Nismo LMGT-4 17x9 with Federal RSR's
Bilstein Coil overs with king springs
Whitleline Cross brace and adjustable swaybars
BrakeLab Pads front and rear
Engine has made just on 600rwhp.
Car will be sold with around 550rwhp on E85
Any questions ring me on 0404812797
Asking $21,000
Edited by HYPED6
https://www.sau.com.au/forums/topic/402174-r32-gtr-with-vct/
  • 4 weeks later...
how much do you think it would cost to get it fixed and registered in QLD again?
thanks
That would depend on what you did with the box. Id say any where between 1k - 7k
GTR Box's are pretty cheap. Straight cut gears are not very cheap.
