Going highmount single, need to sell the twin's to finance.
Happy to sell as complete conversion if someone needs a kit. $2200 for the lot.
Everything is is in excellent condition, was making an easy 300kw and has minimal lag, very good street setup.
Garret -7's $1200
Xforce Dumps $250
Cat forward $300
Match ported std exhaust Manifolds $150
Modified (split exit) std turbo outlet pipe $100
Apexi hardpipe induction $250
Can supply most other std parts if needed for install as I wont be using them.
Also have a std radiator, good condition. No cap $75
Located Sydney, 2558
post-15046-0-94411100-1339293534_thumb.jpgpost-15046-0-94411100-1339293534_thumb.jpgpost-15046-0-78723200-1339293549_thumb.jpgpost-15046-0-84590500-1339293564_thumb.jpgpost-15046-0-39068000-1339293580_thumb.jpgpost-15046-0-05046400-1339293595_thumb.jpgpost-15046-0-07258800-1339293639_thumb.jpgpost-15046-0-07071800-1339293686_thumb.jpgpost-15046-0-21657200-1339293822_thumb.jpgpost-15046-0-91805400-1339294029_thumb.jpgpost-15046-0-02736500-1339294008_thumb.jpg
https://www.sau.com.au/forums/topic/402178-twin-turbo-setup-7s/
  • 3 weeks later...
