One of my mates in sydney has sourced this turbo setup for me, what looks to be a T06 to fit an RB25, manifold, wastegate, and other lil bits n pieces. All up he wants $1200 for it, but he dosen't know if it works or not, I need to let him know by the end of the day if I want it or not. So basically my question is this... if I pay this amount n it turns out to be a dud, what can I do with it, and would I still be able to break even or lose less than $200 on it? I'm not really looking for a profit if I resell it if its not what I need, so what do you guys think? should I buy it?
He mentioned something about a 9mm something or other and it will bolt onto an RB25 and there's a small dent under the front pipe? comes with the AFM as well...
ahhh decisions decisions... quick, someone tell me what to do. How much is a broken TD06 worth anyways?
https://www.sau.com.au/forums/topic/40222-whats-this-turbo-setup-worth/
Actually, having a closer look at the 2nd set of photos looks as though they have welded a T3 or T4 flange to the exhasut housing of what may be a TD06 series turbo (it kinda looks triangular instead of square) so that it can be bolted to the manifold, which does appear to be a twin scroll,
Considering this would mean quite a mismatch of the inner diameters/faces id suggest there is a reason why its so cheap, but still if the manifold doesnt have any cracks and the wastegate is in ok condition then they are worth the money, i dont think the turbo will ever work well with that manifold, so could sell the turbo with correct exhasut housing to recover some costs
yeah it appears as if they've used a manifold for an HKS turbo with a trust turbo, which is wierd. Its a triangular to squar mateing job. apparently the inners of both are the same diameter... so :
Its not a TD06-25g compressot housing, they have Greddy cast into them like DJ Lethals TD06-25g... its more then likely a TD06-20g like mine, althought the compressor looks different so may be an older TD06-20g turbo, does it have a tag on the comrpessor cover, if so what colour is it blue and silver or black and silver
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
