Ok so as boosst let the cat out the bag before i had got the car up to scratch here is my new project. the only real reason for the car is i cant do a huge amount to my 350z as its pretty much the car i want it to be
so i found this beauty....
Her spec is as follows
1996 Series 1 Stagea
Greddy E-Manage
Greddy FMIC
Turbosmart e-Boost 2
FCD
HKS Induction
Garret T30 Turbo
Blitz Downpipe
HKS Decat
Torque Flow Back Box
Tein Coilovers
4pot front callipers
Grooved & Dimpled Discs
Twin Pot Rear Callipers
Poly Bushed Uprate Susspension Arms
Tein Adjustable Pillow Ball Tension Arms
Series 2 Rear Lights
Tinted Rear & Back Windows
18" Wolfrace Wheels
DVD Headunit
Infinty Speakers
Clifford Concept 650 alarm
Remote start
Prosport AFR
Prosport EGT
Prosport Boost
https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/
So i started the conversion on thursday morning so here are the pics
in the morning
Kit positioned
Headlights cut into place
Test bolt up
Semi finished front end etc
I can confirm that you can make the factory bonnet catch work you need to drag forward about 2 inches i used stud and nuts to do this however the bonnet catch is quite a stiff ****** so needs to be braced from below or it wont shut and latch
also factory hinges with r34 tops dont work for the masa bonnet, it sits far to low and has to be spaced (temporarily) 13 x m8 washers per side to even come close plus the actualt hinge is to far over and has also been spaced to even come close to the mounting holes on the bonnet........
so few more pics now
As you can see the bonnet still doesnt line up right i think this is due to the fact there are to many variables on the bonnet line up so need to solve this before i can get the lines right.
thought this wont stop me getting the car Wrapped ASAP
alll thats left now is the rear Splitter to fit but this requires some modification and it was raining lol
so turned out i was missing a headlight bracket so had to order the drivers side one of these
whilst i was at it i got the GTR bonnet latch re-locator and GTR hinges i didndnt fancy cutting them apart so i for now have made wood spacers namely due to the fact i was dong this an hour from my metal working facilitys and i want to get the exact height it needs to be so far sitting at 35mm height change whilst still using the R34 GTR hinges complete
so with the car now lined up properly we could see the differences in the dimensions of the kit and i wasn't happy so out came the fibreglass and filler etc and here we go
gap before
fiber glass added
Filler added
so with the kit now lined up propperly time to get on with the prep to paint
we did flat it all down etc and started with the filler primer
Unfortunatly there had been some touch up work done and the paint even though flatted reacted badly with the primer so had to be sanded down again and treated with barcoat
to plat it safe i did the whole front of the car in it
even inside the shuts
New coat of primer applied
No reaction so carried on
so now waititng for that to fully arden for a few days before any base coat is applied but here is the workshop/ Spray shop
Ok so yesterday I had the day off work so after a early start to get the last few bits do e it was time to paint started with the skirts
After a few coats we left those to harden and after about 30min in the polly tunnel it was time for the bumper
Again few coats later and lunch time for the wings
We deliberately sprayed onto the bonnet to get a thick coat on the edges as we're expecting as with most cars that to be the points that could get damaged easy
So...
Also did the fuel filler car and the bump strips of the new wings
Will do another few overall coats this morning then start with the lacquer depending on how quick it all goes off will depend on if it drives away this Sunday or not......
Stay tuned lol
Ok so end of another day which started off not do well there had been a reaction over night to something we suspect a mixture of 2thinners maybe the culprit so had to sand the wing back again few more costs then again untill no reaction was left didn't fancy going all the way back to Barcoat as thats lots of work etc
So once this was do e we carried on few more dustings on the rest of the car then a light rub down and lacquer time now this stuff goes off quick dependant on mixture levels do we had what we thought was a 25min window per load turned out due to mixture and heat that it was a 10- 15 min window lol
So after 4 passes this is the state
ok so thats the second weekend over with an still its not on the road :(
but we do have significant progress
there was a few runs so we gave everything a quick rub down and then re lacquered
so the moment you have been waiting for well i hope you have anyway lol
The body work unfortunately has orange peel i think to do with a mixture of things mainly the heat it got to in the room during the spraying rather than after where you bake it on so this means i have to flat the orrange peel down to get my glass finish i want so that's next weekend sorted :(
here is the comparison
what are your views anyone had orange peel from spaying before etc.....
Ok so I must be mad but spent the day outside in the rain with the wet and dry paper sanding the orange peel out so we now look like this
This is how it did look
If the rain will do ne tomorrow I will hit the car with the g220 cutting compound then polish it ready for the ace cafe next week......
Well we have success but was without its moments, if anyone attempts painting the car again dont try and use the Meguiers G220 to get out the Orrange peel or even the aftermareth of using 1000 - 2000 gritt paper as its not man enough. i found this the hard way
so had to go and buy a new Sander/polisher but once i did wow what a difference cut through the scratches alot easier and brought the car up to a nice shine
so here is the finished article prior to leaving the Booth today
So i drove it back to the ranch and gave it some love so after a clean and a hit with Poor boys Black Hole we look like this
So here we go this was the paint match on saturday
So i tried to polish but no such luck due to being the wrong paint on the rest of the car so on sunday afternoon i started masking up and monday morning / Lunchtime it got bar-coated
sanded the high spots of then hit it with colour
So after 3 and a bit coats of paint
It was time to leave it over night the roof isnt right and requires a further coat as its so big and such a pain to paint its got alot of imperfections but im hoping that i can get lacquer on it tonight and maybe tomorrow sand the lacquer again and hit another coat on
keep your eyes open for more updates lol
all in all it was about 7 weeks but this did allow for me not working on it during the week as it was at my weekend house (big garden as you can see)
Most of the time was spent on the front end and side skirts preparing for paint etc the rest of the car was mainly a blow over which was about 2 weeks work
Wow you dont waste any time huh? That was about a years worth of thread posted in 2 days!!
Turned out beautiful, i like the S2 rear lights too!
Seems to be a few stunner stageas from the UK.... any further plans for the car?
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
