I have been told by mechanic that I have a R4 Engine in my Skyline R33 S2
Thats the reason some of the wiring is different on this one.
I have a High Idle of 1000 RPM+ , I had a problem with Aircon in summer that If I would turn that on my car will just die.
So I was looking at some wires I found that MAF and AAC wiring are left as is and not connected.
I got two plugs spare that are not in use , I remember that they were connected in my old S2 ( that I sold :( )
can anyone tell me what to do with these one ? I've marked them with green color!
Any help will be highly appreciated
https://www.sau.com.au/forums/topic/402253-where-do-i-plug-these-ones/
Dev man
the guy said its running a haltech ecu but when i saw on left hand side its normal ecu with many wires cut
itsjust better to get rid of this engine and put a stock one
The engine is fine, its the engine management you need to sort out to see which one you have.... It may have a haltech as a piggy back somewhere?
BUT first thing i would do is get rid of the BOV as that is really not going to help your cause.... I put an atmo on my R34 for about 3 minutes before i realised it sucked! THEN sort out wiring!
  • 1 month later...
Follow the wiring from the motor in the Idle Air Control (IAC) valve on the rear of the inlet manifold & see if it's connected. I have a funny feeling the little red curly thing in the picture is the power wire for it, & it doesn't look connected. It just ends. As for the two female plugs, The brown one could be for the valve for the charcoal canister, which isn't there. The greyish looking plug could have been for the factory boost pressure sensor. Both of these are located in that area on my S2 C34, although the plugs are different shapes, the grey one is boost pressure sensor. Your best bet is to find someone with a stock R34, or even a dealer. Pretend your buying a car, lift the bonnet & have a good look!!!!!!
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
