Techedge 2A1 Wideband sensor controller.
I was running this controller for years with no problems, butchanged the setup a while back, this has been gathering dust since
What you get: A techedge 2A1 wideband o2 sensor controller. Includes onboard datalogging of the o2 sensor and up to 7 other sensors. Comes with an RJ45 splitter so you can connect a gauge and PC at the same time. New equivalent units are about $250.
What you still need: An o2 sensor (Bosch LSU) and cable. Tech Edge sell them for about $150.
What you probably want: An o2 sensor display. Tech Edge sell them for about $150.
Price: $50, pickup in sydney. Willing to post at buyer's expense
More info: http://wbo2.com/2a0/ , http://wbo2.com/2a0/2a1.htm
no problems, $50 with a free WB02 controller :P
to be honest this is cheap to just stop it gathering dust.
*edit* just saw why, the splitters retail for $99,999.99! http://wbo2.com/hw/splitter.htm
Why the hell not, got a mate that will probably need the WB Controller anyway.
PM me bank details, and i'll transfer $50 + $10 for shipping to WA when i get paid at the start of the month
Cheers
  • 1 month later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
