Hi All,
In the last couple of weeks and mainly since our cold Melbourne mornings I'm getting the hand brake dash light staying on in my R33.
Sometimes the light will turn off immediately after the hand brake is released then will turn on again after several seconds, but mostly it will remain on until the engine has been running for 10-15 minutes. For the rest of the day it will continue indicating correctly.
Now i'm wondering if this light might be used to indicate any other car related issues? I do have a power fc but as far as im aware it only uses the engine light for sensor maxing and the rest of the warning lights should act as they did with the OEM ECU.
The car doesn't appear to be driving any different than normal, and it may very well be just a faulting switch on the hand brake. But this starts to seem unlikely when as mentioned early sometimes it does go off as it should then turns on again (without touching the hand brake)
Any help would be very appreciated.
Thanks
https://www.sau.com.au/forums/topic/402319-hand-brake-light-staying-on/
it also indicates low brake fluid, which can also be an indication that your brake pads are low. check the brake fluid level. if it's low then also check your brake pads, because the lower the pads get, the more fluid is in the calipers and less in the reseviour. if the pads are low then only put a small amount of brake fluid in to get the light to go away, otherwise when you put new pads in you may end up with brake fluid overflowing when you force the pistons back into the caliper
Yeah check this
I got caught out searching for a dodgy wire, ripped my seat out and started pulling the floor carpet up and checking the wiring. Then checked the fluid and it was low. Topped it up and light went away. I found my light went out under braking sometimes
Thanks guys, I did wonder when I was in the car the other day if it might also relate to the main braking system.
I tried pumping the brake to see if more pressure made any difference to the warning, but no dice.
The reservoir is below max but still within the indicated min mark. Will give a little bit of a top up and check out how the brake pads are fairing tomorrow. Certainly still have a firm pedal feel so hopefully its just being over sensitive to the reservoir level.
Thanks again and hopefully I'll have good news to report soon.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
