Hi All,
In the last couple of weeks and mainly since our cold Melbourne mornings I'm getting the hand brake dash light staying on in my R33.
Sometimes the light will turn off immediately after the hand brake is released then will turn on again after several seconds, but mostly it will remain on until the engine has been running for 10-15 minutes. For the rest of the day it will continue indicating correctly.
Now i'm wondering if this light might be used to indicate any other car related issues? I do have a power fc but as far as im aware it only uses the engine light for sensor maxing and the rest of the warning lights should act as they did with the OEM ECU.
The car doesn't appear to be driving any different than normal, and it may very well be just a faulting switch on the hand brake. But this starts to seem unlikely when as mentioned early sometimes it does go off as it should then turns on again (without touching the hand brake)
Any help would be very appreciated.
Thanks
https://www.sau.com.au/forums/topic/402319-hand-brake-light-staying-on/
it also indicates low brake fluid, which can also be an indication that your brake pads are low. check the brake fluid level. if it's low then also check your brake pads, because the lower the pads get, the more fluid is in the calipers and less in the reseviour. if the pads are low then only put a small amount of brake fluid in to get the light to go away, otherwise when you put new pads in you may end up with brake fluid overflowing when you force the pistons back into the caliper
Yeah check this
I got caught out searching for a dodgy wire, ripped my seat out and started pulling the floor carpet up and checking the wiring. Then checked the fluid and it was low. Topped it up and light went away. I found my light went out under braking sometimes
Thanks guys, I did wonder when I was in the car the other day if it might also relate to the main braking system.
I tried pumping the brake to see if more pressure made any difference to the warning, but no dice.
The reservoir is below max but still within the indicated min mark. Will give a little bit of a top up and check out how the brake pads are fairing tomorrow. Certainly still have a firm pedal feel so hopefully its just being over sensitive to the reservoir level.
Thanks again and hopefully I'll have good news to report soon.
    • Oh and my rear arms may need some attention too.
    • Bushings are almost done. Check the date stamp 😂 these are likely the original bushings with 27 years and 243ks on them.     Was too dark to get a pic of the worst one.
    • Porous blocks are a known issue on something like a Porsche M96, it's not really something I've ever heard of on an RB26. It's possible what people thought was a "porous block" was really a cracked block that they just didn't spot the crack on.
    • This is a controversial subject really, the whole power vs fun thing I mean And this is the main reason I got back into a MX5 Of the last few notable daily cars I've owned whilst I have frequented SAU R33 GTS-t: fun, but because I'm a idiot I modified well past a reliable fun car and ended up hating it, although that was my fault because I tried to have a daily cruiser and race car all in one, the family called it the sometimes car, because sometimes it was working, sometimes it was broken, gladly sold it NB MX5: brilliant car, thrashed the Bejebus out of it, but, again, was stupid and deleted the air con, power steering and stripped the interior out, whilst still fun, and reliable, and super cheap on consumables, it was not a fun place to be going on long cruises, I did love it, but basically every family member hated going anywhere in it, sadly sold it 2015 WRX STI: soulless thing that looked like your average Kia sedan and had that horrible boxer engine with glass ringlands, the family did like it though, that thing was one of my stupidest purchases and I still regret it 2017 Toyota 86: 😪 if I didn't crash it, I would probably still have it, it was a fun little thing, even with that horrible boxer engine, the family did like it, the only reason I didn't get another 86, or, BRZ was the boxer engine, I should have learnt after owning the STI, but I'm a idiot VX SS: great cruiser, fits the whole family, and was fast as.....in a straight line, but a big fat thing, so no enjoyment throwing it around corners, the family was unimpressed with the whole boganness of if, but they did admit it was a comfy place to sit on long cruises As for the NC, I feel it is perfect for what I want, or need out of of a car, whether I'm cruising the Hwy, back roads, twisties or peak hour traffic, the Mrs doesn't mind driving it either, or cruising in it as well, although she does bump her head of the roof nearly every time she gets in, which is farking hilarious, and the kids love taking it for a thrash as well So basically, I've had constantly more fun, and way less headache and heartache, both on the track and on the street, in low powered cars,  go figure.....LOL One thing though, the Mrs has stated that the cams have made the exhaust sound much louder, which they have, but it doesn't bother me, in fact, I actually like it, but, to negate any future comments from the Minister for War and Finances I may look at some changes to the rear muffler set-up to drop the volume down a tad to appease her when we are out and about in it
    • You will need to extend the turbo inlet pipe somehow, which could/might be done with silicone/rubber pipe, but might need steelwork, depending on your intake. And you will need to change the pipework on the outlet in teh same way, but this is more likely to need steelwork.
