Has anyone had any dealings with these? Picked one up for my 34 and only looking to run 7-15psi and been told they are fine for low boost applications but cant find any decent write up comparing the two other than one having a larger solenoid than the other.
I have the smaller single solenoid like this one in the link below and the old type controller like this, not the twin dial one with the digital screen
Any help is appreciated
http://www.ebay.com....=item3a74d32cd6
Edited by rb2534
https://www.sau.com.au/forums/topic/402335-blitz-boost-controller/
Not sure about tha one but i used the brand new SBC from blitz, supposedly only been out from japan for a month with no english translation and its safe to say i hated it. I couldnt get stable boost no matter what i tried. Not sure whether it was the customers install or not but it ruined my liking for it.
Most of the other blitz bc's are awesome
Yeah from what ive found some people say the single solenoids are fine then other say the bigger solenoids are fine. Guess it will be a case of hooking it up and seeing how it goes, from what i can tell on the instructions the box with the fitting goes to a vacum source on the intake manifold and the solenoid tees in between the turbo compressor and the wastegate controller
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
