Hi all,
I tried to go to the introduce yourself section of this forum but it comes up with an error msg. So seeing I joined to talk about & find out about Stagea's, I thought I would introduce myself here.
I once owned a 93 Skyline R33 sedan and loved it but it had some issues (bought it from a dodgy import dealer) so I got rid of it, then after the next non grey import and too much attention from the fuzz I got into four wheel driving to slow me down etc. So after a long time my love for fast cars has come back & now I'm a dad I needed something practical like the 4x4 but something to still enjoy and admire. Enter the Stagea....I just bought a low km series one auto Stagea RS4 AWD with Hicas :unsure: (Already looking at Hicas lock out bar)
So I have a few questions that I couldn't find exact answers too:
1. My Keyless entry doesn't work?, (I replaced the battery as I'm the first owner of this car in Australia)
2. Where can I get a workshop manual in English? (PDF format is fine)
3. Do these cars have a factory immobiliser?
4. Do Stagea's use OBDII diagnostics as I have a Scan Gauge II from my previous vehicle?
5. Where is the plug for the above?
Thanks for any help, it would be much appreciated.
Welcome, you will find answers to most of ur questions if u use the search function, just have to do a bit of reading. Just saying this cause ppl usually get flamed for asking question that hsve been answered a million times before, the answer to ur keyless entry should be in the stagea diy section
I did do some searching but maybe not enough....thanks for the heads up!
Welcome, Nice stagea, The Stagea's always look the best with the dayz front bumper.
I like this body kit, the side skirts are a bit damaged though by the previous owner from Japan.
Hi
should be able to find workshop manual on ebay, no factory immobiliser.
I wouldnt put a hicas lockout bar on unless you get an aftermarket ecu as it will cause the stock ecu to think that your hicas is failing and may cause more ecu issues than its worth.. Thats the advice my mechanic gave me and he should know as he had a Stagea and did so with his...
Hi
Thanks, I'll check out Ebay for the manual & thanks for the info on the lock out bar, but I already bought one.... Now I'll have to sort the ECU out, it never ends with modifying does it :rolleyes:
Just ordered the manual from ebay, thanks bjd. Where should I get a immobilizer fitted in the SE Brisbane area? I want to search the DIY section, but each time I get an error or it kicks me out back to the main forum page.... Moderators help needed!!!
A lot of info seems to have got lost/become inaccessible since the last revamp of the Website.
So far as I know the workshop manual has not yet been translated. There is an owner's handbook available. You can find R33 manuals online which take care of most of the mechanicals.
Does your central locking work? There is a tutorial on how to tune your key to the car but maybe the receiver is faulty.
The ecu is accessible via Nissan Consult not OBD - there are a number of aftermarket devices such as ecu talk
http://www.ecutalk.com/
that give you access mainly on a read only basis. The plug is behind the coin holder to the left of the fusebox.
HiCas delete should be the same as for the R33 so have a look in the skyline section (hopefully that is not broken too) and there are tutorials on getting rid of the hicas.
Thanks Kiwi,
I ordered a CD service manual off eBay today...
It's a shame all that info isn't accessible as its one of the reasons I joined this forum. Is it going to be fixed?? The Hicas lock out bar details have been explained to me. I will try searching the Skyline section for the other issues... Thanks again!
make sure you check the threads for the latest qld Stagea meet: confirmed for Sunday 24th June: would be good to have you along...
Thanks for the invite - I'll try and make it, but the day before the Stag is in the workshop getting coilovers, tie rods & Hicas lock out bar fitted. So hopefully it all goes to plan!?! Edited by Troppo
I'm in Brissy & have Nistune consult cable & software, I can come round & give you a hand if you like?
Thanks RB Bluey, if I can't get the central locking working I might take you up on that offer...
consult won't help with the central locking
it has probably had an aftermarket alarm/immobiliser installed at some point and they may have cut something
i'd be getting an adr compliant immobilizer fitted anyway as justcar won't insure you without one and most places give you a discount if you have one fitted
technically not correct, they will still insure you and take your money, but if it's not installed and you try to make a theft claim they will turn around and say no because it's one of our conditions that it is fitted. i really should get round to installing one in mine someday. :unsure:
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
