Hi all,
I tried to go to the introduce yourself section of this forum but it comes up with an error msg. So seeing I joined to talk about & find out about Stagea's, I thought I would introduce myself here.
I once owned a 93 Skyline R33 sedan and loved it but it had some issues (bought it from a dodgy import dealer) so I got rid of it, then after the next non grey import and too much attention from the fuzz I got into four wheel driving to slow me down etc. So after a long time my love for fast cars has come back & now I'm a dad I needed something practical like the 4x4 but something to still enjoy and admire. Enter the Stagea....I just bought a low km series one auto Stagea RS4 AWD with Hicas :unsure: (Already looking at Hicas lock out bar)
So I have a few questions that I couldn't find exact answers too:
1. My Keyless entry doesn't work?, (I replaced the battery as I'm the first owner of this car in Australia)
2. Where can I get a workshop manual in English? (PDF format is fine)
3. Do these cars have a factory immobiliser?
4. Do Stagea's use OBDII diagnostics as I have a Scan Gauge II from my previous vehicle?
5. Where is the plug for the above?
Thanks for any help, it would be much appreciated.
Welcome, you will find answers to most of ur questions if u use the search function, just have to do a bit of reading. Just saying this cause ppl usually get flamed for asking question that hsve been answered a million times before, the answer to ur keyless entry should be in the stagea diy section
I did do some searching but maybe not enough....thanks for the heads up!
Welcome, Nice stagea, The Stagea's always look the best with the dayz front bumper.
I like this body kit, the side skirts are a bit damaged though by the previous owner from Japan.
Hi
should be able to find workshop manual on ebay, no factory immobiliser.
I wouldnt put a hicas lockout bar on unless you get an aftermarket ecu as it will cause the stock ecu to think that your hicas is failing and may cause more ecu issues than its worth.. Thats the advice my mechanic gave me and he should know as he had a Stagea and did so with his...
Hi
Thanks, I'll check out Ebay for the manual & thanks for the info on the lock out bar, but I already bought one.... Now I'll have to sort the ECU out, it never ends with modifying does it :rolleyes:
Just ordered the manual from ebay, thanks bjd. Where should I get a immobilizer fitted in the SE Brisbane area? I want to search the DIY section, but each time I get an error or it kicks me out back to the main forum page.... Moderators help needed!!!
A lot of info seems to have got lost/become inaccessible since the last revamp of the Website.
So far as I know the workshop manual has not yet been translated. There is an owner's handbook available. You can find R33 manuals online which take care of most of the mechanicals.
Does your central locking work? There is a tutorial on how to tune your key to the car but maybe the receiver is faulty.
The ecu is accessible via Nissan Consult not OBD - there are a number of aftermarket devices such as ecu talk
http://www.ecutalk.com/
that give you access mainly on a read only basis. The plug is behind the coin holder to the left of the fusebox.
HiCas delete should be the same as for the R33 so have a look in the skyline section (hopefully that is not broken too) and there are tutorials on getting rid of the hicas.
Thanks Kiwi,
I ordered a CD service manual off eBay today...
It's a shame all that info isn't accessible as its one of the reasons I joined this forum. Is it going to be fixed?? The Hicas lock out bar details have been explained to me. I will try searching the Skyline section for the other issues... Thanks again!
make sure you check the threads for the latest qld Stagea meet: confirmed for Sunday 24th June: would be good to have you along...
Thanks for the invite - I'll try and make it, but the day before the Stag is in the workshop getting coilovers, tie rods & Hicas lock out bar fitted. So hopefully it all goes to plan!?! Edited by Troppo
I'm in Brissy & have Nistune consult cable & software, I can come round & give you a hand if you like?
Thanks RB Bluey, if I can't get the central locking working I might take you up on that offer...
consult won't help with the central locking
it has probably had an aftermarket alarm/immobiliser installed at some point and they may have cut something
i'd be getting an adr compliant immobilizer fitted anyway as justcar won't insure you without one and most places give you a discount if you have one fitted
technically not correct, they will still insure you and take your money, but if it's not installed and you try to make a theft claim they will turn around and say no because it's one of our conditions that it is fitted. i really should get round to installing one in mine someday. :unsure:
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
