Hi all.
In the final stages of my efi conversion on my Nissan patrol.
Having some hassels with wiring. I am able to get 12v to my coil. But getting no spark past my coil.
I have put computer into diagnosis mode and are getting back the following codes.
Code14 vehicle speed sensor
Code 22 fuel pump circuit (using a seperate solinoid set up)
Code 24 neutral park switch ( manual computer)
Code 31 heater/ac
Code 32 starter signal circuit
Would any of these faults prevent me from getting spark?
I was thinking it could be the starter signal circuit, I have located this wire in the loom, but I am unsure where to get a starter signal from. I was thinking putting accessories 12v to it. But given that it's a black with white trace wire. I have decided not to try this.
Was hoping to get some advice and thought here would be a good place to start.
Thanks Cam
Edited by showtime393
https://www.sau.com.au/forums/topic/402375-rb30-patrol-efi-conversion/
Hi
I have done Agnew of these and the only problem I have had is the ignition source needs to come from the old coil wire as the others don't have power when cranking. Double check the pinouts on the ecu.
Good luck you should be wrapped with the result.
    • Good to see your rotors appear as rusty as mine šŸ¤Ŗ
    • Took it for a drive to do some logs, Iā€™m pretty sure my voltage issues and electrical noise issues are gone, Iā€™ve sent a log to Adam and am waiting to hear back with confirmationĀ  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4 Ā  idle video from that day just becauseĀ
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!) Ā  Ā  I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding). Ā  I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springsĀ  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
Ɨ
Ɨ
