Sweet result and love the vid
That's what I want power wise from the racecar when I build it
Congrats on the house as well Ruxis and welcome to never ending bills bills and more bills LOL
Random house news for me is I just ordered a new kitchen which Melisa is happy about
Am thinking with all the offers floating around I should mention I have a Karcher of anyone needs to clean the car engine bay etc
Awesome to see the the group working together :yes: we have a good thing going....
Car has had its final tunes today, has been set on -
311rwkw on pump 98 low boost
340rwkw on E flex low boost
357rwkw on E flex high boost
These were all tuned for safety and reliability and show the turbo is out of puff...
Some car news from me
Had an early finish so got a head start on detailing the car.
I forgot how much work it can be, have spent all arfternoon on it and not even half finished
I've only got the bonnet roof rear spoiler and boot lid done so far
The rest can wait till tomorrow to get the final polishes and waxes then the windows wheels and interior
Good work mate, look forward to seeing your car again next weekend..
Going down to get the car Monday mate so will definately be there :D
Is there much midrange or torque difference between low and high boost?
And where do you get e70 around here?
3 servos so far in the Newcastle area... Charlestown (that reminds me, better fill up on that meet up), Hamilton and i think Swansea.... Its good stuff!
There isnt going to be a huge difference between the 2 i dont think mate, still more than i can handle lol
And now I'm finished
Taken long enough but is so much better
Today was one pass with power finish
Two goes with the final finish
One with the sealing wax and finally some P21S carnauba wax by hand
Put the rear spoiler back on cleaned the wheels, windows and interior and is now all shinny again
PM me a moby number or email and can send them
Wouldn't know how to post then to be honest
i did the other day about the diffuser lol. I'll upload them for you if you want.
You can use photobucket.com to upload images --> create an account (free) and then just follow the prompts. it gives you a url that can be pasted into your posts.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
