Could be something different and is of interest!! Nice call with the road behaviour too!! If there is updates etc and you havent seen us post in there make sure we get a reminder :thumbsup:
So let me see if I got this right
Weight reduction stage one = having a piss
Weight reduction stage two = having a piss and a dump
Is that right?
They are stage 2 & 3, most importantly you must remove the boot carpet! Best bang for buck modification so ive heard :P
Ah okay
So what is it if I remove the back seats as well?
If you go to that level you will need an ANDRA license and parachute from what i hear!
think of the welds on your intake manifold :|
and your floor pan falling out (guess its more weight reduction though)
is that like stage 4? strip the car down to the bare chassis, the motor, running gear and a drivers seat?
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
