Haha nah already did that with 250kw so it's all replaced :P
Haha
It's something I'll never have to worry about with the ultra progressive power delivery from the auto box, least I hope not anyway
Though I did do dome rough measurements and worked out if I move the trans cooler and air con thermo fan I can fit one of those Just Jap stealth front mounts in without cutting the bar, should be good for something, choockie reckons they are better even on stock boost
Haha
Your drivetrain will be fine ;)
I have to get a thin Davies Craig fan for A/c as mine was removed due to the huge plazmaman cooler, your Trans cooler can go on the drivers side and the fan can be replaced....
If your not gunna up the boost don't worry about the cooler, OR run E85 :P
It's already running 12psi
Plan is to go the front mount, injectors , Z32 AFM and a basic highflow or just get steel wheels so they last and that should do as far as mods for decent power
EDIT Wanna stay with 98 fuel as can get it anywhere
Edited by m.j.h
Hey guys, for those of you that dont know.... My clutch is now toast :P Didnt think it would last long at the power level considering it was way outside its happy zone!
Should have been double clutching not granny shifting :D
ANYWAY, that puts my car out of contention for the 26th as Jim Berry will be working his magic on my clutch around then.....
Ill still probably jump in with someone tho, CHOOKIE???? :woot:
Martin you still keen to drive my car to mats for cruise? if not mat make you way to mine :P otherwise i wont be able to come :'(
Yeah I ran around 250kw on 13psi like that.... You may get away with a side mount
Yeah I'll come get it if needed man, either way it'll work out fine!! :)
Awesome yay i wont not be able to go :)
cefiro is sold finally, 1250 but also got 3" front partt of the exhaust and highflow cat for the skyline, might try get those in before cruise if i have time :)
Your a goose :P
I'm back what's up guys.
Sorry said hello then bailed.
I didn't read any of the previous posts but skimming I think I saw the words women and naked. Newcastle chicks are the bees knees
We missed ya :P
We mentioned that the WT brings the Lulz....
Oh and plenty of broad minded personty types up here if that's your fancy lol
I don't know if it's the forum or the iPad but I have to laugh at the way it changes S L U T to broad minded person and T U R K E Y to the schpinter of the universe
It's the forum
Like the word kunt spelt with a c turns to
flamin mongrel
Or add an s to it and you get
dream boats
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
    • Turbotapin   so I am about to be mounting mine up been waiting for the body to get finish at paint. I had a question. I was told our Speedo sensor it originally in the transmission but the cd009 is in the diff on the z. How did you get around this?
    • I definitely do recommend having a fab/grinding/dirty shed or area to keep all that grinding dust out of your main shed.  But you're right, it doesn't matter how much room you have you still end up filling it! I might even do a short video which will make it easier to fully take in the horrors of what I've created...
