On a completely related unrelated note..... Dad just swapped a corolla for an Alpha for his wife and reckons the selespeed gearbox brings the lulz
Does not surprise me
And now for something different.........
Who knows what that quote is from?
This is the Newcastle thread not the Lulz thread
Now where is Manuel to derail it with random pics of bitches
THIS!! :yes:
electric seats, did it have seat warmers? im not a fan, your bum gets so warm it feels like you may have shit yourself :unsure:
well maybe thats just me :action-smiley-069:
Dude! You are not sitting in my car without these -
Yep seats where heated as well.
Bonus with those cars was the seat would lay completely flat................fun times where had in that car
THATS where they got heated........................... Amirite? :D
Yep
Funny story when Melisa and I first started seeing each other and was doing work with Dad one day he asks me if we chrstined the Alfa. I said yes
What about her car
Yes
What about my van
Yes
What about your other car
Yes
What about the Falcon
Which one? I ask
Either one he says
Both says I
He won't let me test drive the Daimler now for some reason
Yep
What about her car
Yes
What about my van
Yes
Yes
Which one? I ask
Either one he says
Both says I
hahaha top work :P
someone has to christen them ;)
Yep
What about her car
Yes
What about my van
Yes
Yes
Which one? I ask
Either one he says
Both says I
So this is your work van?
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
