got a reaper up top of my arm, started on my sleeve, still have 6 hours ahead just to finish the shading on him, but hey be worth it :D
after this is done in next fortnight focus is back on car parts again haha
On builds just acquired all my parts required to finish off my first stage of engine mods..
Doing decent service on it before ebc, cam gears and tune happens next month... Heaps keen!
What EBC did you end up going with or still deciding?
Do you still need those cam gears Ant?
what else do you need for your future -9 upgrade? i have a few parts lining around (new injectors, can prob get you my old(but new) vipec ecu cheap too)
Hey mate, don't need the cam gears anymore sorry mate, ended up getting some new tomei ones for a really good price, they turned up today.
Ah roughly for the -9 upgrade would be adding:
Turbos obviously ha
Different ecu
Injectors and pump
Clutch
Think that's about it, kinda gong/hoping for a simple but effective build.
Yea those parts sound interesting mate if they would suit the above?
What about oil pump for oil starve ant??
Don't you need lots of supporting mods in a gtr?
Yea havent looked into whats required for oil etc yet too much, i know there will probably be a few little extra supporting mods to do when the build happens.. but at this stage mainly concentrating on whats required to make my power goal, then go from there as its still quite a way off.
Not sure if i need to go crazy with it though as its not a track car, if i was making it for track then yea i would go crazy with that stuff.
Turbos obviously ha
Different ecu
Injectors and pump
Clutch
Simply, but effective build list
The nismo injectors are 600cc - perfect for that power range unless your going e85. Also, I lied - It's a link G4 ecu not a vipec (essential the same) that i gave to Paul - i'll ask him if interested in selling it
100,000km service wouldn't hurt either.
Crazy - Nitto/Tomei pump, cam baffels, 8-9L race pan, race pan baffles/gates, oil restrictors turbo/head, catch can, oil cooler
moderate - billet gear replacement, sump baffels, catch-can, oil cooler, 1L overfill
basic - n1 pump, sump baffels, 1L overfill
cheers for the info mate, will send you a pm regarding parts etc..
Hahaha the only way to bed in a tyre is skids...................................................... Trust me.......................................................... :ph34r:
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
