lol - it was regarding Ant's pods...
I had a question about them ...then i thought...I have 3 different intake boxes and a set of pods in my garage, I don't really need another intake lol.
ha probably a suitable amount then! i will be posting a for sale add tonight.. and probably tyres too as i just got some pics.
Hello look forward to seeing you again. :action-smiley-069:
Will be good to say G'day again :D
Maybe you should get a spare gearbox as well just in case
Yeah Jim said i need to learn to be mechanically sympathetic as the box is the next weakest link!
Got a HID kit being installed, come clear indicators and maybe a BOV. should be done end of month :D
Please NO BOV...... Clear indicators and HID are epic win though! :yes:
agree, stock gtr bovs to the job just fine!
Good for 400kw+ ive heard!! So please keep them and spend the money on useful upgrades :yes:
Be good to catch up for a cruise once i am back on the road.... My clutch will take 500km to bed it apparently so once its going i reckon thats a weekend lol
then skids on my stockies :D
Hahaha skids will be on the menu! On a private track of course!!
I'm not allowed to side step the clutch with this new thing :/ he said it makes gearbox go BOOM!
    • I don't run the spring but it means you need to set your own belt tension.  I put tensioners on both sides too.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
