I'm pretty sure 33s can run similar wheels to 34s.. I think 32s need to run a little smaller.
33 parts are very changeable with 34 parts also, pretty much same coilovers, strut bars etc, different head though
head is the same, the exhaust cam is different
yeah fair enough,
thats another thing then, if i wanna get a 34 later on (ofcoarse) i can swap all parts straight from 33 to 34 which would be cool.
think i like the chunkyness of the 34 and 33s better then the smaller 32s.
like the massive front bars with the low lips etc.
oh, r32-25t, welcome to sau newcastle haha.
Mine could be pretty low by that time, but with storage issues it may not be haha
Good roads and good fun.... Will post pics and get your feedback! 2 Min Noodle reckons we'll be right
I could have brough out the E90 Corolla for some spirited driving...
1.4L Motor with Carby + FF Layout = Win.
Where's a good brake place around here? Might get some rear brake pads
I want QFM a1rms, dunno if anyone would have them around here
Just get them through GSL Rallysport mate! Cheap and easy to deal with.....
I am only running the HPX on the rear as its only going to get the occasional track thrashing!
Yeah its just a 500degree not 600 i think but has better cool temp properties....... Our cars are really heavy on the fronts so i will run the bigger better pads etc on the front!
Yeah fair enough, I got stock pads on the back, should I expect a good upgrade from these??
Your not pushing the limits of the rear brakes on the street so not really, however you may get an advantage on Wakie, more so the pedal wont fade as quickly.........
Ive hand Endless brakes since ive had the car and they havent faded once, been amazing brakes! But rears are finally gone!
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
