Oh btw, going to look at that clean white 33 in Newcastle sarvo :)
Nice man.
and that ferry the ramps are steaper then they look in thoes pic's i lived down there for like 4 yrs boat access only. You could do a run down to Pie in the sky and eat there but that may not be long enough for you guys, ill be joining the pack around gosford on the way through.
My Godzilla will take its 1st breath on the new engine this week and be ready next week, i just hope she still spits flames once its rebuilt it scares the shit out off ppl when u go from 1st to 2nd and spit going down the main street in gosford hahhaha.
fair call on the ferry.. im still happy to make a split meeting point for the people who want to go the ferry route?...
all that sounds good though mate.
no vcam for my car, can find areas to better spend money.
update on my ecu.. its basically been chipped by a company in japan that there is about 1 licence in aus to tune it haha.. so i will be going for the haltech :) and i got the ok to have work off too so very happy! my bank account wont be though.
Make sure u keep that ECU you may be able to offload it on here for some good $$$ if its a rare item, btw where was the shop that has the licence to tune it?
Yea I'm keeping all stock parts....
The guy that can tune it is up in Brisbane I think from what JEM informed me
Ant, have you considered the HKS V-Cam System..
http://www.hks-power...vcam/index.html
Costs about $7,000 though (not including shipping from Japan)
thats only for the pro system - which that only made 30 off.
the step 1/2 versions are ~ 4000. You can also buy some of the parts seperate, which can make it cheaper, depending on the whats is trying to be acheived.
Most of the decent builders/tuners in australia have there own setup by modifing the neo intake gear to run on the rb26 head - alot cheaper :-) Mine will be possible getting this next year, depending on how responsive my final setup is.
Edited by wedge_r34gtr
Aww but sky wants to go on a boat ride!!
f**k you stance phags.
Haha oh benji please gtfo of thread.
Wish there was a ban from Newcastle section button.
Hahahaha.............. Nice! :P
Park it on top of an R33
Nah dont think we should split the group mate, we will just stick together :)
Oh a nice call on the Haltech! You'll be very happy with it :yes:
Interesting about the ECU chip too!
Nice man.
Dont mention pies or Chookie will start drooling.
Hey guys i have a question about the transponder in the R34 GTR keys, my car has a aftermarket immobiliser installed and the original remote is not used, i only have 1 key and 1 remote for the car and i want to get a 2nd key/remote. What i want to know is the transponder in the key, is that still used when an aftermarket immobiliser is installed? and where can i get a 2nd remote for it. and am i better off just going and getting a new immobiliser/alarm put in that i have all the codes/info for and spares.
Because i have NFI i am going with NEW ONE :woot:
The old key may open and close the doors but won't turn the alarm off.
When I put mine in I threw out the old central locking system and fed the new alarm with the original wires. Which is probably what they would of done with you.
To get a new remote you'd need to find out what brand it is and either take it to someone so they can program it, or possibly find a code inside it? It won't be as cheap as it sounds I'm sure. Mr minute may be able to dodgy one up for you for 50 odd bucks???
I'd try mr minute or alike, then get a new one. But if your getting someone to install it it could cost a bit.
It's up to you.
hahah this guy, i like it.
i think i might call and ask about
http://www.npsonline.com.au/shop/item/4-star-car-alarm-01
this shit seems good, alarm, immob, turbo timer, price seems ok to. I just need to know about the dam key chip thing :domokun:
Oh oh oh J-RAD, Was down talking to Aaron @ Difftrans and he said your fkd :P Said the stock 34 diffs are a waste of space haha
At least i tried!
It's up to you.
Yeh i just got quoted around 1k for a full Viper alarm with turbo timer and immob, but its not a 4 point and the only insurance company that will touch me since im 23 is just car at this stage and they require a 4 point in the car and i now need to find a dam key with a transponder in it and whats even better is i dont have the code for the transponder i hope they can code it off the key i have.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
