FYI -
R34 GTR wuith aftermarket immoboliser in most cases still runs NATS which means you need to get the transponder programmed before the key will start the car.
R34 GT-T with aftermarket immoboliser does not need programming and you can get a key cut and it will just turn and start.
Thanks for the info, and welcome to Far North Newcastle :D
FYI -
Thanks heaps for that, going to get a key today then ill have it coded when i get the car back :D
well, some think planks of wood if no one has any propper ramps like the ones u use to get cars on the back of a trailer, use them to take out a heap of the angle off the ferry ramp
Martin was all over the planks of wood idea, the ramps are good but unless we get a stagea or a ute to come then they would be too long for all of our cars i reckon!
Not if they are short enough to sit in the boot.
Four short planks would be better than two longs ones and save a bit of time as well
I can still bring timbers and lots of them as well
But I like the idea of making a decision on the day
Well OK, lets go back to Plan A.... Ill set up the cruise including the Ferry based on your wood etc and THEN if we get any epically low cars on the cruise we will make the call on the day! Once again we can always split and meet back on Old Pac but would rather try keep the group together!
Happy to help.
I got one of my keys programmed by a mobile locksmith called Ultimate Lock in Sydney. It was around $100.
Cheaper than Hornsby Nissan. I received the same quote of ~ $180.
And not done by an apprentice ;)
hey man my wood is always good :3some:
Ok just bought the new key, will have it coded once i get the car back, then ill sort out the immobiliser, atleast ill have a spare key now :yes:
    • OK, so all I can suggest is that - if you have all the parts, and you have all the wiring looms, and you have all the electronic modules, then....it really is just a wiring problem. You likely have a damaged wire, pin, etc, somewhere.
    • Yup, bought this bad boy and hopefully it will be ready to pickup today. Had $5 credit on top of it so it worked out really well!
    • Yeah it is really until until you get a feel for it....then it is easy. Which is no use to you really. I'd buy that torque wrench. One thing from sure, many (most?) tyre shots overtighten the f**k out of wheel nuts, so don't worry if they were tighter when you tried to take them off compared to when you do them up. I've had some crazy tight ones come back from shops, quite apart from the potential damage to the thread, I can't see a smaller person taking the wheel off on the side of the road
    • Hey mate, thread dredging hahah To answer you directly, yes I had my itbs oversized and custom butterflies etc made by EFI Hardware in Sydney back around 2017-2018 if memory serves. My setup had a vast amount of other changes too though, so no direct comparisons unfortunately. i went from oem itbs, HPI manifold and internal gate hks 2835 pro S; to 49mm itbs, cnc port matched Nismo plenum, RB25 Neo lower runner adapter hand port matched, r31house v2 Takoashi MAX equal length twin scroll manifold with twin 38mm tial gates and a FP HTA3076 with 1.01ar twin scroll real hosing. feom power Fc to a link fury wired by 12volt, r32 gtr fuel tank conversion with frenchys twin 460 / surge tabk fuel hanger combo kit, 1659cc injectors, full 4 inch turbo back stainless exhaust, Z34 6 speed, Tomei 2way with 4.3 final drive and a ton of other shit. ive posted elsewhere here with complete run down, but here's a graph from its initial tune with no boost control on, 20psi gate springs only and e85.   7542AE72-DA92-4E0B-8660-B0940FEA7F24.mov
    • On sale mate, $55. Sorted. https://www.supercheapauto.com.au/p/toolpro-toolpro-torque-wrench-1-2-drive/565734.html?utm_content=paidsearch-pmax&gad_source=1&gclid=Cj0KCQjwytS-BhCKARIsAMGJyzqYEnwWmhWf6gxTST_Nz06Gd2VePgyvL7lh6PWrQtbjXTsI6TqSCLEaAuaCEALw_wcB&gclsrc=aw.ds
