Benji, you should remove all the paint off your car... Would be a saving of several Kgs I would think, and about as useful as removing boot carpet and number plate plastic ;)
What are you talking about that 70g should take at least .5 of a second off a track time :laugh:
Then spray in yellow and get all the chicks eh? ;)
Hows your beast going Ant? Any results? I am excited!
:whistling:
Hahahaha.
If you think about it, weight reduction is the CHEAPEST way, to improve power to weight ratio.
E.g. Stock S15 = 147kw/1200kg = 0.1225kw at flywheel per kg of weight
now if I was to delete 150kg out of the car....then this is what would happen
147kw/1050kg = 0.14kw at flywheel per kg of weight
To put it in perspective
I'd need to be making 168kw at the flywheel to achieve a power to weight ratio of 0.14kw/kg with a 1200kg S15
Thus!!!
168-147kw = Equivilent of 21kw gain
No results yet, hoping I get a call sometime this Arvo to find out how it went... I'm very keen also.
I think benji would have to shave all body hair, and possibly remove seatbelts? Haha
So by your idiotic logic then you will need to remove over 200 parts off your car the way you are going in order to go faster!
You sir, are a fool! :no:
Send me a message when you know as i am keen to find out :D
And Benji, try spitting and not swallowing and you should save some weight :laugh:
I THOUGHT you were told you werent allowed to cause this sort of thing or TROLL on here anymore? If you get me in trouble for encouraging it then i'm not gunna be happy! :dry:
Haha, I'm not trolling.
I am trying to become more D.I.Y minded, so it seems the easiest D.I.Y thing that I can do is delete things haha.
I've still got to see the mechanic about brakes, I dropped by the workshop at around 5.30pm yesterday and everything was closed up =\
I need to get one of those last 15 track day spots
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
