Benji did you just compare yourself to DK?
I should slap you
He has played GT4 which theoretically makes him the fastest driver on the planet... Or so his thread said anyway.
Well that was my first time driving the car. Car had no mods, borderline metal on metal brakes, a passenger, a full tank of petrol, leaking struts, high rear end (due to strut sag in the front), and stock everything when I set the 1:19 laptime. And I wasn't pushing it to hard because I didn't want to risk crashing.
Sooo, if the mods get the mods installed....I expect to shave a bit of time off.
I mean, even with just the full exhaust system I'll gain around 40rwkw, and HKS coilovers and alignment arms will mean much sharper turn ins etc.
And what tyres do you plan on using?
I need to find some tires for around $150 size 235/40/18
For 2 tyres? Mick_o just sold a heap for cheaps mang.... I'll keep an eye out
    • What I’m saying is that I never heard of a non gtr 34 coming with a cooling panel stock or factory option. Maybe they might’ve I don’t know
    • Yes, at least 10 years before anyone ever thought of making such a panel. Of course.
    • I bought one for a 32 and it was junk, found its way into the bin
    • have a look at the other 2 stock rubber strips marked in blue. As you can see, they press against the cooling panel and leave marks. If the cooling unit panel isn’t there, the strip press against nothing therefore have no use. So Nissan was thinking ahead when they manufactured the cars, as they must’ve known people will install the panels in the future. Otherwise think about it, why else would they be there? Therefore that in itself directly infers that cooling panels do something. It might be to stop water and stop some air from going above the cooling panel so more of the air can be redirected between the cooling panel and the front bar towards the condenser and radiator. I tried to take a pic of it while the bonnet was closed but u can’t see shit in the photo
    • @DraftySquash @Duncan i misspoke, or this might be the other way. someone sent me a low res pic of it on It might completely close off the gap in red like in the second pic (second pic has gktech cooling panel on) .The 3 holes are for the plastic rivets used to secure down the front bar. The outer holes on the radiator side go underneath the condenser brackets If thats the case then there’s going to be no air going in through the grill between the bonnet and the bar for the radiator and condenser. Isn’t that bad? I mean less airflow to the radiator and condenser is all I’m saying
