  On 12/10/2012 at 10:09 AM, 34GeeTeeTee said:
Get the parts and give me the car for a weekend!
Will let you know once parts are organised....
Will shout a case of beer etc unless youd rather cash
Also, I would sell my left testicle for this Supra
  On 12/10/2012 at 10:51 AM, Ruxis said:
cheap but still out of my price range for the rotors haha. free is a good price :D
Check out the new Brakes Direct rotors? Ask Oweban about them, he's fitting some up...
  On 12/10/2012 at 9:50 AM, 34GeeTeeTee said:
Fark all.... Watching some shit on TV with the dogs lol (wondering if Chookie has killed himself via coilover yet)....
No he didn't kill himself
Gave him a hand and wouldn't have got the job done without a lend of a socket from my toolbox
Coil overs fitted as well as front castor bars
Good stuff! Bet he is smiling hardcore :D
  On 12/10/2012 at 11:13 AM, m.j.h said:
Yep just have to adjust the left front two turns and tighten all the bolts and job done but h can handle that
Car looks mean now
Awesome...
Missed abit in here.. Been flat out as usual...
Going shorty to get my coilovers fitted too, getting very keen!
Not sure if we're going to bother with a mini cruise this Arvo though, weather is looking average, and I'm not sure on interest?
Will still try and organise a time and place if people are keen..
yeah not sure if ill be able to come or not. if your keen swing me a text.
god dammit... was gunna to oil cooler this morning but i left my socket set at work...... MI NEED MOAR TOOOOOLS
anttttttt think i could borrow your brand new socket set tomorrow/sarvo? :P
Lol u can do it here if you need to borrow tools J-Rad although it's a bit of a hike... Have u checked all the lines fit? Made a bracket etc? Don't undo anything until you do that, also is it 100% clean and been sealed?
it has a bracket made to suit rb25s lol, not sure if itll fit a gtt but ill work something out.
nope it has been sealed or cleaned i dont think? haha. what do i clean it with?
its been surrounded in bubble wrap for the past 6 months
Went into bowers suspension to get some prices on coilovers and the told me they were fitting some bc's onto a yellow 34 gtr which im guessing is you.
Let me know how they go for you, im looking at getting the same ones fitted. Did they fit any other suspension components like bushing etc?.
It looked real good and he said he was happy with the service.
Pretty sure they adjust everything for you and I can't see why they wouldn't do that
Just letting you know cause he mightn't see this for a while.
Are you new to the forums?
Been a member of the forum for over 4 years but i never post, i only come on if im looking for something or need a question answered.
You may have seen me getting around newy, i have a white pearl r34 gtr. owned it for just about 5 years now.
Nice, I think I've spotted you too :thumbsup:
Bring her out on the 21st mate, plenty of 34's going and a good chance to get some good pics etc
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
