S A U__N E W C A S T L E
GTR-34A
Fark all.... Watching some shit on TV with the dogs lol (wondering if Chookie has killed himself via coilover yet)....
No he didn't kill himself
Gave him a hand and wouldn't have got the job done without a lend of a socket from my toolbox
Coil overs fitted as well as front castor bars
Good stuff! Bet he is smiling hardcore :D
Missed abit in here.. Been flat out as usual...
Going shorty to get my coilovers fitted too, getting very keen!
Not sure if we're going to bother with a mini cruise this Arvo though, weather is looking average, and I'm not sure on interest?
Will still try and organise a time and place if people are keen..
yeah not sure if ill be able to come or not. if your keen swing me a text.
god dammit... was gunna to oil cooler this morning but i left my socket set at work...... MI NEED MOAR TOOOOOLS
anttttttt think i could borrow your brand new socket set tomorrow/sarvo? :P
Lol u can do it here if you need to borrow tools J-Rad although it's a bit of a hike... Have u checked all the lines fit? Made a bracket etc? Don't undo anything until you do that, also is it 100% clean and been sealed?
it has a bracket made to suit rb25s lol, not sure if itll fit a gtt but ill work something out.
nope it has been sealed or cleaned i dont think? haha. what do i clean it with?
its been surrounded in bubble wrap for the past 6 months
Went into bowers suspension to get some prices on coilovers and the told me they were fitting some bc's onto a yellow 34 gtr which im guessing is you.
Let me know how they go for you, im looking at getting the same ones fitted. Did they fit any other suspension components like bushing etc?.
It looked real good and he said he was happy with the service.
Pretty sure they adjust everything for you and I can't see why they wouldn't do that
Just letting you know cause he mightn't see this for a while.
Are you new to the forums?
Been a member of the forum for over 4 years but i never post, i only come on if im looking for something or need a question answered.
You may have seen me getting around newy, i have a white pearl r34 gtr. owned it for just about 5 years now.
Hey guys,my sparkies need changing,
can any one tell me a shop who won't charge an arm an a leg to do it.
Oh some where fairly close to fingal bay woul be good. :action-smiley-069:
Nice, I think I've spotted you too :thumbsup:
Bring her out on the 21st mate, plenty of 34's going and a good chance to get some good pics etc
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
