Sneak peak at my engine bay - will still need some work in Perth, but getting there:
Catch can looks fanatastic. Wish i had the plenum painted black now too.
Edited by wedge_r34gtr
haha good stuff on the kms!!
ah thats no good martin!! im about the same, working tomorrow morning before our drive so i dont mind a quiet one :)
if anyone wants to sus out some roads me and martin are gunna go for a cruise tomorrow.
Yeh well as long as i have boost ill be going, im not to sure whats the deal with it, gave my boss a lift he said it was rly fast and i was just like meh boost does not seem to be working, i can hear the turbos spool and it has some boost but does not fell like maximum boost, maybe its just me imagining things and im used to it so it needs more boost now, meh fark it for tonight will get it sorted tomorrow when the new rad goes in ill let u guys know lol.
yeah man could be a number of things but i wouldnt think its serious, if your boost gauge is still working it could be something with the boost controller.
just ask your mechanic if he changed anything, because a lot of solenoids have to be pointing in a certain way
Ah Righto, no good for a cruise?? Well scope it out and see I guess.
The road to broke looks like a 1 lane situation too. I suppose sat Arvo will be one o the busiest times so today will be a good test.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
