i got some good quality bank notes of the best grade A+( USD, GBP, CAD, EUR) and also can issue your fake/legal documents, anyone interested should hmu ASAP. notes are high quality and perfect for usage and also i offer some samples in case you want good business, so if you need just contact me on TeleGRAM: @Ranko322 or Wickr: Ranko322 or whatsapp +639950791362 i also do Face to Face deals in case you want proof first. Samples also available
Fitted, will adjust the angles of the fittings once I fit up the loom. Under plenum, really wanted to convert that barb to a 6AN but yeah nah, wasn't a true 3/8" so that conversion fitting didn't work. Less messy now, the coolant hose mess is now gone! -
Has no effect on the steering itself. Is for idle control.
By DraftySquash · Posted
Sorry to reopen an old thread but I’ve been having the exact same feeling as you mentioned. I was tipping up my PS fluid today and noticed that while the car was on and stationary, the steering wheel shudders when I’m doing full lock. It wasn’t exactly on the full lock but maybe about 75% turned in one direction. although, I also found out today that my power steering valve was broken by the previous owner and it was just glued together 😂 that glue had cracked again so it was leaking air. I’m not sure if that’s what caused it.
