S A U__N E W C A S T L E
GTR-34A
I could be wrong, but I'm pretty sure it's the other way round mate.
Who's telling you this? The seller?
-9s are An updated version of the -7s, pretty much the same response as the -7s but flow a fair amount more. -9s on the same set up make more than the -7s etc...
i spoke with DVS Jez, and a few other ppl they will make the same power diff is, the -7s have more top end and the -9s have a bit more down low, but in the end they will both do the same job.
also ill be getting a platnum pro plugin for her.
Edited by T4NK
yea fair enough, i really thought it was the other way round though. -9s being slightly bigger but better in design, therefore only a tiny bit more lag than the -7s but more top end..
i was fairly certain the -7s were the smallest upgrade turbos you could buy, but there is so much confusion around these turbos that i wouldnt be suprised if i had it wrong haha..
Wedge you know abit about this dont you?
The only difference between them that i can find was the exhaust wheel 1 was like 3mm bigger then the other or somehting like that. But i cant wait 3 weeks for -9s anyway so -7s will have to do im over all teh waiting and f**king around, just want it to run so i can enjoy the car.
yea fair enough mate.
just be easy on the clutch when you get it back, its generally the weakest part of the car from stock. and it is advisted when going with bigger turbos to upgrade it etc..
you doing anything else bar turbos and computer?
I'm not 100% sure but i believe the exhaust housing is slightly different design on the -9 too.
-7's = r34 n1 turbos
-9's ARE HKS GTSS turbos
The graphs i looked at when researching turbos showed <150rpm difference between the two (-9's been slightly worse), but the -9's usually had the better top end (10-15kw's), however this is highly dependent on supporting mods and i couldn't find any back to back comparisons (who's going to waste 2.5k to go from 7's to 9's unless the've blown a turbo)
TBH throw 20-24psi through either of them and your going to be making ~330awkw and absolutly exstatic. You can't really be disappointed with that.
Edited by wedge_r34gtr
Good stuff - that means all three of us a runing platniums.
all this talk of turbos is making me very keen for the next stage on mine..
seriously going to have to consider E85 i think.. have seen results with a similar planned setup as mine making 370awkw!
will be hard to pass that potential up i think..
Yep - I've been saying for a while i rekon it would be possible to crack 400awkw with E85 with 9's.
Someones 34nur in melburne made 379awkw with 7's (stock n1's) and E85 recently.
Yea I reckon 400 would be too much for those turbos... Could probably get a dyno to read it, but how accurate?...
I'm pretty sure both run out of puff around 22-24psi?...which would restrict huge top end power etc...
Yep, going to do mid pipe on my exhaust since the cat back is 3 and a half inch and so are the dumps but has the stock mid pipe, also needs a new clutch as mine is almost shagged, will do injectors and maybe fuel pump with the ECU, then after i have it all sorted in a year or so i may put a big single on it when i get another car as a daily, and go for massive power since the engine is built for it.
ohh and i hope everyone has taken the restrictor out of the side of the stock air box to, it just pops out 2 clips just use a flat head screwdriver, will double the air into the box, i can now hear my car sucking in that sweet sweet air as i thunder down the roads lol.
Edited by T4NK
    • The official serialnine instructional video shows it as being installable in the car, but it's going to be a pain on an R32 as room is very tight. I run a CD999 in my R32 and I have doubts it can be done. From the looks of it, I believe it will still work fine with a cut shaft, but maybe give serialnine a call to confirm.
    • For more clarity - because the sedan tailights are square-cornered where the coupe ones are round, and because the coupe boot lid doesn't work on the sedan, the method to do this has been to cut the sedan bootlid/reshape that part where they are different. Plus more f**king around. There are old threads on here such as  where it gets discussed and it hardly seems worth the pain.
    • Are you sure you want to stick with twins?
    • So I have my cd009 installed in the car with the gktech relocation and I’m not entirely enjoying the shifter placement. I found the serial nine cd999 shifter relocation and although it’s pricey it looks to be a better fit. My question is with the trans in the car will I be able to just remove the old shifter bracket and install the new serial nine? To fit the gktech I cut the selector shaft will the serialnine work considering I did that? The installation is the main reason I’m hesitant on getting it.
