Either way sounds good.... I was going to be at the Bathurst 12hr race etc but dunno now so cruise is on the cards....
We can use Chookies car as the turnaround point, itll be upside down in the middle of the road kind of like a roundabout :ph34r:
probably aiming it for the 10 of feb? everyone good for that?
not sure on the route though, i had one planned but i think it needs to be done in winter to avoid summer/beach traffic, but it could be ok by feb?...
otherwise do north end of putty, but not sure on a good turn around point? anyone have any ideas?
I may be able to make it not sure yet
Edited by Chookie!!
10th of Feb is my birthday, birthday cruise sounds good to me :woot:
"you both have a barrel at the end of the street to go around, 1st team down and back wins it"
would it better suit you guys the weekend after?
also chookie, hows the car? find something after the run?
So I've got a job interview tomorrow .....
Field Sales Rep.....
Not sure how I feel about knocking on strangers doors to try sell them stuff. Seems like the type of job thatd get you punched in the face.
Also applied for a style assistant job at kotsra westfield in one of the department stores =D =D
Bahahaha best call!
As long as its not Powercruise weekend i should be fine!
If you knock at my door ill punch you in the face............................................... Even if you are not working :laugh: just kidden Benji
i think the wheel alignment is just way out now?
ill know tomorrow going for another wheel alignment :(
If you've gone really low with the coilovers youre going to need adjustable arms to get the alignment right
benjiman
i have all adjustable arms
just need it aligned cause i can see the front are way out just by sight
Ive painted the inside of the house and finished the ceiling since you saw it :D
Oh, i think i found another cloth, sponge furry thingy of yours.... A blue one?
Good stuff, bet it looks a million times better than it did before, now get those floors sanded
Yeah probably mine bring it with you on the 20th if you can
Hello boys,looking forward to seeing all your handsome mushes at the end of the month. :yes:
Not mine you won't , a face only a mother could love is mine.
I'll be in Kempsy on that Weekend for the first round
http://hillclimbnsw.org.au/cal.pdf
If I miss out so be it but I reckon a good turn around point would be the halfway cafe but if I'm not there my opinion don't count LOL
What's a style assistant?
    • The issue still requires a human to get all the logic right, and each thing being done takes up processing power. Meaning less processing power for other tasks to occur too. It also typically means a team of size 10, is working one everything, vs 5x teams of 3 working on separate products, so less man power to review and perfect it all.   That's the typical issue of AIO. It's also why manufacturers of cars even split tasks out into separate systems, and share data as required
    • Lol, i have and you can buy them in adelaide more just curious if anyone has tested this one in particular
    • Isn't the whole point of this integrated circuit thing to put a bunch of hardware all in one little package? Integration also brings its own benefits, at least in theory. If you were to put an electronic wastegate or do an N54-style vacuum wastegate that is normally fully open but closes under vacuum integrating everything allows you to do tricks like full wastegate bypass at cold start to warm the cats or in eco-mode under a certain torque request to reduce exhaust pumping resistance. Or full bypass as a limp mode if a certain amount of knock is detected. Or managing the compressor so it never reaches the surge point. None of this is strictly necessary per se but standalones generally have good enough boost control. PID control isn't exactly some crazy difficult problem to solve.
    • You've never bought something online before?
    • Hello everybody. I have no idea where to get a ethanol tester besides online and want to run a e30 mix in my bmw m2. In order for my calculator to work i need to know what ethanol rating the e85 pump is and this is my local station would anyone know or is it negligible to find specifically. Thanks🙂
