i dont think he f**ked anything else, just the radiator.
Jarad, An over pressurised cooling system is a sign of head gasket failure. pressurised combustion gasses etc getting into the cooling system.
Edited by wedge_r34gtr
ah right, i thought he meant 22 psi through the turbos? like he was running full boost and it f**ked up?
hah i must of missed that :P
Yeah i'm guessing he did, but radiator's don't blow themselves up!!!! plus the combustion pressure will be alot higher then 22psi.
no way 30! if it has done the HG, its only done it because its made the head studsa little longer.... New HG, ARP fittings, strap it down again and enjoy.
might have just been a brittle old top tank. I've had one crack before.
Yeah I've had a tank crack but never blow apart
But agree with the studs comment
How did it get that much pressure in there?
H/G?
Yeah its possible, very hot day and pushed it hard..... But will get another Radiator and test it before i worry too much.
And ill be staying stock NEO, they are a tough bit of gear.... Mines been limiter bashed, leaned out and cooked and it keeps making healthy power even with 145k's but if the HG is gone then i certainly cant get upset as it was pushed pretty damn hard for a factory part lol
Sure is.... But not to say that was the issue yet ;)
or it's because he had a cheap china radiator in it.
they have been know to fail.
but it looks like it was stock. :/
Stock radiator man! Temps were fine on the dyno even on a 42 degree day...... There is another issue and it could be HG or stuck thermostat etc etc
stop sulking tee tee and tell us what happened!!!
LOL no sulking, Coz Racecar..... Cruising along, Haltech drops into protection mode to make me stop, temp gauge is spot on..... Stopped and temp guage started climbing fast..... Pulled over and lifted bonnet then 5-10 seconds later once the pressure built up and the cooling sys super heated the tank split and made my engine bay nice and white..... So the tank only let go once it pressurised which is a good sign BUT it didnt loose much coolant which is the confusing part as to why it ran hot all of a sudden, the Haltech picked up the temp rise and dropped into limp mode to protect the car, the stock guage is usless and still said everything was good lol
vrroooGAAATTTTTTEEEEEEEE ...................sploosh.
Nope the Gaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaate was that morning, i was just light cruise when the issue occured
well it's 40deg and i've just spent the the last 2 hours "walking the belts" (lots of steps and steep inclines) at work
I'm stuffed :turned: ...need to get fit
10min break then i'm back out there again :domokun:
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
    • Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
    • Nistune needs something like an entire excel spreadsheet in which you build an abstraction layer that converts everything from real units you can actually measure into all of the various tables. The number of unexpected dependencies hiding in how the Nissan ECUs do math is a pretty impressive optimization trick for 8-bit MCUs but good god is it awful to actually work with in practice.
