whos organising the next cruise and where to? its either martin or chookies turn to organise, unless someone else would like to have a turn and choose a route theyd like to show everyone?
Good question
Might have to decide over some drinks when everyone can be there
u may have to stay home for the next cruise if u sell ur car mate.is anyone from newy goin to the top secret car meet at eastern creek on friday night?
Ill be driving to Bathurst, not sure what time as it depends on when I finish work
If you happen to see an old Hiace van towing a white car trailer give us a wave otherwise ill wave from the M4 as we drive past
Yeah sounds good
Could do with the extra help to clean tyres check temps pressures etc after each run
Meet at the circuit 630 Sat morning
i'm already here lol.
why are you going down?
F*ck'd if i know
It's showing up on eveyones now.
Yeah and some kent left 2 Neutral feedback today :whistling: Asshole!
I'm heading to newe tonight. Going to claro around 7pm for some beers and triva and if anyones bored
Having beers and dinner at Raymo with mates if your cruising past!
Bastards!!!
Coming from orange via Sydney, See i'll see how i go :-)
Edited by wedge_r34gtr
Bastards!!!
The leather jacket skinny jean wearing, bread hammer throwing kent!
    • is it common on RB25det motors that the exhaust manifold nuts become loose overtime? I was inspecting some stuff and noticed that a couple of nuts were so loose that I could literally turn it by hand. Everything is stock on exhaust side unless when they installed the dump pipe they had to remove the manifold for whatever reason. I'm surprised the boost leak didn't show up on the test lol.
    • Haha watch Alex's eye twitch when you mention Nistune to him in person lol. He's not a fan, then again it's quite a niche product. I personally don't mind them, but most usually steer clear from it. Word of advice, do not ground the AFM to the chassis, there are heaps of incorrect guides on the interwebs. Send both GND on the AFM back to Sensor GND on the harness.
    • Note I edited my post, so Sleeper's quote is not the same as what I meant any more.
    • That's a whole 'nother issue. Nissan ones get dirty and sticky. The coolant heats the wax pellet thingo to close the valve, so it is open when it is cold. And so if there is no coolant it just takes longer to close, because the heat has to soak all the through the inlet manifold.
    • I feel like this is crazy pills though. Isn't it locked up all the time anyway? It shouldn't flare anywhere if it only unlocks momentarily while it shifts gears. And if it flares like that when shifting gears, then the 8HP with a 5500 stall is not driving as well when on the road and/or track use..
