Meh! Whatever. Id rather support a lil cafe in a country town than eat that commercialised shit any day.
Yeah...I used to think that way as well. But I've been to several the small cafes and take away stores in country towns only to be left unimpressed as a) the food didn't meet expectations and b) fairly overpriced as less people traffic. I've been more impressed by the eateries I've found in metropolitan areas.
What about a little variation on the route?
http://goo.gl/maps/AY7kE
Looks as if there is a cafe at Wootton for some lunch too.
http://www.wootton.org.au/index.shtml
that boral road is death mate, drove it in the gtr once.. was the longest road ive ever driven... its a massive tease as it would be an amazing strech of road, if the surface wasnt so poor. shook me and my mate to death haha..
I thought that may be the case. Seems all roads north from Maitland are all rooted!
working onit, havent had a chance to really take any pics yet, and still waiting on stickers and center caps..
i would hope there sorted by the time the cruise comes around.
Just MMS me a pic ya mug! :P
Sounds like it needs a sack wax!
:laugh: Good call Benji!
there you go, average pics but you get they idea how they site on my wheels.
Mmmmmmmmmmmmm sexy time!
They know what they say about big feet right? :woot::banana::laugh:
big shoes?.. haha
very happy with the wheel/tyre setup.. looks perfect! need to get some better shots, and the stickers on when i get them.
Glad you are happy man! I hope you have locknuts or someone might borrow them for a GTT :ph34r:
haha, i do have lock nuts fortunately..
i think you should get some black LMGT4s for your car though, there not a huge expense in gtt sizes i dont think.
I will need some track rims in at least 9.5 all round once i start getting it all sorted! Soon man!
Our work sponsored a car in the Variety bash, i believe they are all leaving Newcastle Sunday if you guys want to go have a look, here is our one -
LSXa97z.jpg?1
Short notice I know but am heading into the brewery tonight if anyone wants to head out for drinks
No can do! Got EPA'd in the Tow Car haha
Oh and gotta pull a kitchen out tomorrow so ill be having an early night :(
Ill get on it!
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
