gunna try and service big bird this arvo... first hurdle, get it high enough to get my low profile juck under it.... i think i have found the solution by using rubber matts that were left in my house ha.
haha first world problems :P
Hey Guys,
I have been on the forums for a while and had planned on saying hi earlier but have been a bit bipolar as to whether I was selling or keeping my 95 R33 GTR VSPEC.
My car is pretty standard save for a set of -7's and an upcoming PFC/EBC install.
I plan on keeping things pretty simple with the car, keeping it fairly stock and clean (as clean as I can)
Anyway if you guys are planning a cruise or a brew (I am in Merewether) let me know.
Cheers,
Dean
sounds good man.
we do need another piss up... maybe after the track day next week :)
Yep we all need to catch up as its been a while!
Welcome in mate, clean white skylines FTW!
yea we do need to organise some drinks again...
any ideas for dates or venues? maybe something like we did ages ago, and meet up somewhere for a beer and a feed, and maybe a small cruise or something???
I've gotta get moved etc which will take me out for the next few weeks.... PLUS the gearbox has to come out of my car after the track day too so ill have to see how we go time wise, ideally for us it would be around 17/11 or somewhere like that...
sounds good around that time.
might be working, well see
We have two weeks off to set up the house etc (Was the time of for SAU NATS but no kesh for that with the new house)...
Did someone say drinks?
Any weekend but the 17/11 is good
Ill be in Port Macquarie with wifey that weekend
What's wrong with gearbox Matt? You broken something again?
Jarred should be an expert at house stuff by now
Nice 33 as well, I'll keep an eye out for it
Just over a month till my blacks. Cannot wait to start driving the thing. Hopefully ill have it all complete by then!
The car is meant to be finished getting paint repairs next week.
As soon as its out, its getting booked in for:
- Cat welded in
- Flanged Screamer Pipe
- Varex Muffler
- New intake pipe to airbox & new hotside cooler pipe
- Few gauges wired up
And if I have enough left over
17x9 +22 Enkei RPF1 wrapped in Federal 595 255/40r17 :D
Also anyone got any recommendations for the pipe work I need done? (local business around newcastle)
- Weld in the cat
- Make a new diff back exhaust pipe to go to the varex / basic fitting of the muffler
- Cut the plumback and add flanges + a new little screamer pipe
- Hotside cooler pipe (to hole in body)
- Turbo > airbox pipe
Also the wiring of the varex & three gauges (water temp/ oil temp/ oil press).
One person ive asked can do it all for about $1000. Does that seem reasonable?
    • I know it's been YEARS but hunting down that trunk lip spoiler!
    • Absolutely nothing wrong with a Profec or similar. He's on a Nistune, so external boost control is a better option anyway.
    • I would not replace the gauges. A well setup tune should never require any of that. I'm of the opinion that if you can't safely hand over a car to your parents to drive it's not fit for purpose and more engineering work should be done. Honestly I'm not a fan of external boost controller boxes either but if you have to you can shove the controller into the glovebox or something once it's set up. Tee it off the OEM MAP sensor. Also you probably want to put a two pin plug on the new solenoid, bolting it to the OEM location works. Just separate the wastegate line and compressor outlet so it will work on a 3 port solenoid, kevboost was walked through how to do this on an RB26, same idea just different locations on an RB25. You may have to remove the restrictor in the OEM hoses if they're still in there.
    • Yep, it's why in Australia we never brought in the 1 child policy like China.  China can't afford to use the shit they make in their own country as it's too much to risk having only one child...  Or maybe that's how they test their shit before they send it to Australia - they use the second kid that families had when they weren't supposed to as the tester?  They weren't supposed to exist in the first place so no loss if they succumb to a work place incident?  🤣
    • It's also the reason neither Duncan or I can own a car rotisserie
