S A U__N E W C A S T L E
GTR-34A
I will keep an eye on any beers (if its an open invite :) )
My car is off to Nathan @ Newcastle Dyno tomorrow for a tune and boost controller! Not expecting numbers much different than standard but hoping to get a mid range improvement.
Get mine back from Nathan tommorrow, am so looking forward to it, 2 weeks without it. Had a few issues that he's now fixed and also set the boost controller. Will post how it drives tomorrow. :woot:
When are yous guys going to have another R chassis circle jerk again....i mean meet/cruise and make all of us other people in "not real skylines" and other models feel singled out and unwelcome?
Because im keen for that sh*t!
Then set a time and place and see who turns up
Or get over yourself and stop holding a grudge
Hey all, just moved to newcastle ad i am after a decent auto-elec. If anyone has any recommendations and/or warnings that would be great, cheers.
Hi
What work do you need done?
Can't really recommend anyone apart from Nathan at Newcastle Dyno but if its a simple thing I'm sure someone knows how to do it
Hi
My power windows in my R32 are not working after an RB25 swap. I have tried fixing them but haven't got anywhere. Also my dash cluster is not working.
hey guys, havent been on in a while. garage should be started to be built on Saturday if martin ever delivers my stuff! :)
Awesome news mate! Mine is slowly getting setup too -
Looks good matt.
where and how much are those shelving worth? ive got some crappy wooden ones in mine atm that were there when i bought it.. want to clean it up and minismise the amount of shevling for more room.
also would really like to install a door onit as it only has the 3 roller doors atm..
Looks good matt.
Ummm you can get them from Office City over near Islington i think it is... Can get all shapes and sizes! They have an ebay store too which actually lists a lot of the pricing!
Will be a power wire not hooked up somewhere then
You can try tracing it yourself or ring around the lecos and see who sounds good
I really hope it is, as its a 5 minute fix, but i pretty sure its not. I have spent 3-4 hours tracing wires to try and find it and got nowhere.
    • Great to know! The guys from The Skyline Shed are going to sort it out and send what I ordered anyway. Turns out their supplier sent them the wrong stock.  But it's good to know I "can" put this in if needed
    • You do not need an LSD oil in any stock (non-GTR) diff, even if it is an "LSD". This because none of the (non-GTR) LSDs are clutch/friction type LSDs. Either viscous or helical - neither of which require an LSD oil.
    • Hi everyone, I bought the Redline diff oil and the seller has sent me Redline 75W90NS even though that’s not what’s pictured.  I’ve already booked a hoist to go and change my diff tomorrow but I’m not sure if the NS is ok for the rear diff in a R34 GTT I think the NS does not have any slip modifiers so would that be an issue?    thanks in advance
    • Not easy to find pics from 15 years ago, but here is a partial one. Keep in mind that it curved immediately from the airbox, then kept a straight line for the MAF to read correctly, followed by a 45 degree bend straight down to the turbo. This connection was the most difficult as it had to twist as well as bend to meet the almost vertical straight section of the intake.
    • Yes, well, wrt a wheel alignment, there are two types. Either: You have very little added adjustables, in which case the alignment can be done by anyone in any tyre shop or equivalent, and will only take 30 minutes, and so there is no reason to even consider leaving the car there. OR: The alignment is a major exercise because you have adjustables everywhere and so you will need to be taking it to a shop that is skilled and experienced at setting up race cars and the like, and you won't need to worry about leaving the car there.
