I will keep an eye on any beers (if its an open invite :) )
My car is off to Nathan @ Newcastle Dyno tomorrow for a tune and boost controller! Not expecting numbers much different than standard but hoping to get a mid range improvement.
Get mine back from Nathan tommorrow, am so looking forward to it, 2 weeks without it. Had a few issues that he's now fixed and also set the boost controller. Will post how it drives tomorrow. :woot:
When are yous guys going to have another R chassis circle jerk again....i mean meet/cruise and make all of us other people in "not real skylines" and other models feel singled out and unwelcome?
Because im keen for that sh*t!
Then set a time and place and see who turns up
Or get over yourself and stop holding a grudge
Hey all, just moved to newcastle ad i am after a decent auto-elec. If anyone has any recommendations and/or warnings that would be great, cheers.
Hi
What work do you need done?
Can't really recommend anyone apart from Nathan at Newcastle Dyno but if its a simple thing I'm sure someone knows how to do it
Hi
My power windows in my R32 are not working after an RB25 swap. I have tried fixing them but haven't got anywhere. Also my dash cluster is not working.
hey guys, havent been on in a while. garage should be started to be built on Saturday if martin ever delivers my stuff! :)
Awesome news mate! Mine is slowly getting setup too -
Looks good matt.
where and how much are those shelving worth? ive got some crappy wooden ones in mine atm that were there when i bought it.. want to clean it up and minismise the amount of shevling for more room.
also would really like to install a door onit as it only has the 3 roller doors atm..
Looks good matt.
Ummm you can get them from Office City over near Islington i think it is... Can get all shapes and sizes! They have an ebay store too which actually lists a lot of the pricing!
Will be a power wire not hooked up somewhere then
You can try tracing it yourself or ring around the lecos and see who sounds good
I really hope it is, as its a 5 minute fix, but i pretty sure its not. I have spent 3-4 hours tracing wires to try and find it and got nowhere.
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
