looks so hectic mat! dont think mine will look that professional hah.
will still be good though :)
Haha thanks man! Only started so far! More to come... Compressor and airlines to go and possibly some A/C haha
AC is needed in mine...
its like an oven in the arvo.. so bad haha.
Yeah i am not sure if the cable to the shed is big enough to support it yet but a mate is a guru and is sussing it out for me :D We also need to hook up the pump to the 5000L water tank on the side of the shed that is just sitting there not being used!
Guys I need some help! The first time I drive my skyline at night and I've copped a defect :( they have written:
-uncovered pod
-height
-exhaust
-e85 fuel system
-modifications without an engineer cert
Firstly i don't even have an e85 system, I just have a surge tank and 044 in the boot, will this pass simply because it's not what they have written?
I have a airbox to replace the pod, and I have a new quieter exhaust solution that is waiting to be welded in.
Will it need engineers to pass? Or just fix airbox, exhaust and height? Anyone know what will happen with the fuel system? If anyone has stock 33 springs I can borrow it'll be amazing too. Pls help a brother out :( very devod
how much was the fine??
I believe any mechanic that does blue slips can pass you? so change it back and youll be fine? as for the fuel... just hope you got a good mechanic?
did you get an epa?
A very nice bloke named Adam Foster is helping me out. The cop didnt fine me, he was a nice man just doing his job I guess. Adams put on a standard airbox, legal exhaust and stock height springs that he has borrowed. The surge tank and fuel pump are removed so hopefully thats enough, I dont believe I got an EPA as that wasnt written on the defect notice.
Glad to hear he helped you out mate :thumbsup:
And yeah this was the result from that night -
Kooraganag and Wharf Road Newcastle, car hoon operation. Newcastle Police, Traffic Command and Resources from Sydney again last Thursday (12/12/13) targeting these areas in relation to car hoons. Police issued the following charges/results
1 x Aggravated Burnout, vehicle plates seizure and Drivers Licence suspended.
1 x Disqualified Driver
1 x Suspended Driver
1 x Mid Range PCA (DUI)
1 x Refuse BAS (Same penalty as High Range)
6 x separate Street Racing charges
111 Infringement Notices
70 Defects notices issued
225 Random Breath Tests
Police will continue to target these areas.
Okay I need some advice on what could be wrong with my car
It has a misfire that is getting worse and need to get it sorted
Started out only doing it when hot and would drive along fine until it missed ( sounded like the traction control working) and would come up with the check eng light on the dash
Has gotten to the point now that it will miss or just feel slow all the time but the check eng light doesn't always come on
I'm thinking plugs or coil packs but want to know for sure before spending money needlessly
Any ideas
Or anyone got some spare NEO coil packs I can try?
Any ideas
Coil packs are notorious for failing in our cars man! I did my factory set at around 120000km from memory... The splitfires have been good since then!
If you need to borrow some to diagnose mine are pretty easy to get out... Car should be back at my place over Xmas i hope!
I had a missfire since at high boost but that was the coil plug loom that failed due to excessive heat (Plugs went all brittle and fell apart) so check that at the same time.
yep if you need a locomotive that needs fixing im the guy to call hahaha.
yeah but the kits are lean toos, not free standing. so gotta wait till lysaghts open on the 6th before I can sort anything.
pretty annoying
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
    • Your off site links didn't work for me, and in any case it is easier for forum members if you post the pic directly either as an attachment or a link so the information is all in one place. That aside, the sills are the correct place to lift the car, whether with the factory jack or a hoist. Yes you should use rubber blocks with a slit for the seam on a hoist to avoid bending the pinch weld (where yours is currently bent, just bend it back if possible eg vicegrips), and be aware of the height you need in the blocks to clear any sill extensions to the hoist arms as it lifts If what you are doing needs access to the sills, the rear subframe bush would also be strong and secure. I'm not sure what you mean by sidemember (maybe same part I mean by sills) but be careful that your front support point is not too far back as the car is very front heavy and could overbalance.
    • Here's my first iteration - white duct tape so color is off, but this is just a straight line across the bonnet lip. From a geometry standpoint, this is probably closest to what a GTR has. Next up is some $5 white pearl vinyl and some rubber door sill trim, applied to the BACK of the bonnet lip. It's more accurate placement to the GTR, but also follows the body lines on this setup a bit more. Couple more pics on this config incoming: Again, a $5 vinyl and rubber job, it's  POC still and not how I'm gonna run this part. But one thing I'll note is that the black trim does need to "straighten out" a bit, and instead of going completely along the line of the bonnet lip, might be better suited to wrap over the "horns" of the bonnet lip, giving it a less aggressive curve up at the ends.  The correct way to do this would be to paint it body-matched and then decide how you want to make the black line. If you used paint or a pinstripe, you could have the black line go straight to the corner of the headlight where the rubber strip typically meets the headlight on a GTR.   Hope this helps!
