Hey guys!!!! I'm sorta back :D
The thread is TL DR so someone will need to catch me up, although i know we have Trike warriors and cars being completed..... Martin the trouble make is back and Chookie is getting more ink?
Oh and a swear i saw Captain Natro in here too?
Saved a fair bit of money from the stupid Ocsober thing so far so it will go towards tyres and oil cooler for the nats......... Oh and buying a 3082 as a backup for my turbs!
Well just as i suspected, the GTR has been delayed again, this time the tomei gasket kit is not in stock, so it wont be ready till monday/tuesday next week and im in orange all week, so im going to have to pick it up friday arvo when i get back from orange, then i can give it a drive to and from work on saturday and then the cruise is sunday, so ill be taking a fresh engine on this run, 2 days out of the shop. So i wont be doing any crazy pull sor anything so ill probs take up the rear as ill be going very easy on her.
Ill pick it up and bed it in........ Hows the clutch :ph34r:
Lol sounds like a bit to much for me anyways
With stock low mount manifold and piss ant exhaust etc on pump fuel i doubt its making that power, and low mounting a GT35 is a bit suss?
AND 500rwhp is roughly what i have NOT 400kw as Mr NPC said :P
Lol, new ad -
http://www.skylinesaustralia.com/forums/topic/411372-monster-r33-for-sale/page__fromsearch__1
Dunno what old mate was on about, he said plazmaman cooler not plenum lol BUT would like to see what it needs for 1000rwhp :laugh:
Not sure if I posted this here or another thread but have a read and then see if you wan to take it easy still, best way to glaze the bores and kill the rings is to take it easy in my opinion
http://www.mototuneusa.com/break_in_secrets.htm
Have run in plenty of engines by loading them up first run and never had any dramas
If the shop has a dyno maybe they can run it in on the dyno for you before you pick up the car
http://www.mototuneu..._in_secrets.htm
well if this is the case im sure my mechanic will run it on his dyno b4 he gives it to me, im going to wait to see what he tells me what he wants to do with it as he is the one offering warranty on it if something goes wrong. If he wants me to smash it then get out of my way GTR coming through and ill see u guys at berowra as ill need the wood ramps to get on the ferry :woot:
Haha ya clown ;)
Yeah most modern rings bed in pretty quickly....He will tell you what to do!
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
