yay found a supplier 14 bucks including postage! yay
Awesome mate! At least you are doing it properly....
does anyone here own a motorbike?
becouse i have one but i don't have anyone to ride with. :(
Where you from Matt? If its Sydney way i know a few people you can ride with ;)
nope i'm around lake macquarie area.
Fair enough, got mates up here that are riding all the time.... Will keep you in mind and if they head that way ill shoot you a PM :yes:
You coming cruising on Sunday? Bring the bike?
Was just told if anyone is seen with a phone at work outside breaks there getting in heaps of shit :(
This will effect my efforts of becoming a whore :(
If anyone sends me a text I'll get to it at 9 or 12 or 230.
Your work fails :P
On that note, my wheel alignment just failed lol.... Young bloke was confused by so many arms to adjust, will have to wait to the boss is back haha
Hahaha it's my luck man! I have NONE.....
Started working on big brakes...... DBA is out of stock of the rotors I want and new stock comes in the weekend after nats..... Faaaaaaark
nope, i will be busy preparing for my holiday. :)
i will be off roading yes. :P
If that's the case gimme a yell when your back, my idiot neighbour and his mates love offloading.... Jack rolled his old 4runner twice!
I missed the last cruise cus we got stuck in the bush lol
Ok so the sandwich plate goes between the filter and thread that the filter screws onto. There's a hole in the sandwich plate for the original thread to go through. The hole in the plate is also big enough for a round fitting to screw onto the old thread, that centers the plate and tightens it at the same time from the hex that is between the female and male threads.
The male thread is on the other side of the hex that sticks out of the sandwich plate for your filter to screw down to
http://turbometrics....es/IMG_8459.JPG
As seen here. So f**kin easy yet no one has one :(
It's just a female to male extension of the same size and I bet my old workshop would have one :(
I just found out pirtek is in Cardiff so they may be able to help. Also Gunna hunt for one on eBay now
http://www.rawbrokerage.com/RB-Oil-Filter-Stud-Direct-to-Block-nissan-oilfilterstud.htm
if you really want to get rid of the mess of the standard oil cooler, just use an rb20 oil filter mount, you just have to re mount the std oil press sender, or if you use the std, aftermark oil temp and press you can get t pieces from enzed and the like to have two senders of one hole
is this the same thing?
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
