Hey mat,
Emma has told me her dad won't be in gosford for the night before Wakie! Do younknow if there's any vacant places for Thursday night???
Ruxis, just do an early morning run to Wakie...
Theres bugger all traffic at 4am in the morning, you'll hit sydney at 6am, miss most of the traffic when the sun is rising and get to Wakie by 8ish.
Thats probably when I'm leaving. The old man is probably tagging along with me to come spectate, he used to have a stack of old cars like a couple of worked LJ Torana's, VK Group A Brock Commodore etc...wish he didnt sell them. He's even been talking that he wouldnt mind doing a track day in the S15 haha.
Also, found out my aunty sold an immaculate 260z (with original bonnet scoop - rare as f**k) for $2000 several years ago because it had engine problems. Facepalm.jpg. My uncle did something similar when he sold his SLR5000 Torana for bugger all (ages ago due to packing the shits from getting hassled/defected by the police all the time).
Moral of the story, don't sell nostaglia vehicles, HOLD ON TO THEM haha.
Could do man but that's f**kin early to then race around all day and I'm only going for the Friday.
I could stay with my folks but that's a 3 hour drive still. Suppose leaving at 5 isn't to bad.
See what happens. Could even stay at a town near ghoulburn
Don't want to modify the stock rail to get my larger bore injectors in - so i'm ordering a 11mm billet rail.
Just wanted to know if the stock regulator can be removed so i can reuse it or if i had to get a new one. Been in the middle of butt f*ck know where atm, i can't just go look at the car to find out ...
Ohhhh.... Aftermarket are cheap enough if you cant use it anyway man!
Hey mat,
As in motels etc? Should be plenty man! Jump on Wotif and have a look, should be able to get a cheap room for a night with a park for the car etc........
I think the adrenalin from racing around the track will keep you going haha.
Matt, I've sent you a PM
and just realised you have organised someone to do the paint, so my PM will be irrelevant haha!
Yeah all good! Thanks for trying tho.........
Yep fouled plugs will give you a nice miss as you come on boost.
i'd be asking y did they foul too! you may be running rich down low - i.e. time for new o2 sensors.
Edited by wedge_r34gtr
Yeh they cleand everything out cleanded the AFM out she kicks even harder then before now its a joke i cant move in my seat when boost comes on and its only putting out .9bar
LOL
that happens.
keep an eye on the plugs. if it happens again, then the original issue hasn't been solved.
Or they forgot to install rings :ph34r: lol
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
