No way benji, the track is heaps tiring specially in summer. I always get so f**kin drained!!
Will do mathew!
f**k yeah tank!
Ill get tired and the blood will probably give me a headache from hanging upside down in the Gravel trap for extended periods of time :woot:
And who you calling Mathew ya kent! :dry:
Yeh even the mecahnic was like FFFAAARRRRKKK when we got out of it, it f**king hammers now with the new plugs i cant wait to get a power run done i think i may have to call Mr DVS
I hear he is only doing Mazda 3's now?
:laugh:
Whats this "WE" business white man, i was leading the pack :woot:
U knw he was taking it ezy lol ZOOM ZOOM BOOM :woot:
next cruise looks awesome to, will be great cant wait for the 100km zone with duel lanes will make for some awesome photo's
You will have brakes fitted by then?
Most likely before the nats, just waiting on the rear pads to come in!
Brake install will be slotted rotors, changing fluids, new hoses for calipers, new pads, and new hardware kits.
LOL, why is it so hard to have brakes fitted,
1. call GSL rally sport
2. wait 3 days for pads to arrive
3. call decent mechanic book car in
4 have pads installed.
works 90% of the time 100% of the time
this goes for all the other parts to just add them to step 1 and 2
Edited by T4NK
Turns out I can stay with emmas dad :) cheers mathew ya sweetie!
Some flamin mongrel just parked over my driveway when if he drove 5 metres forward he'd be off it in unlimited parking.
We wrote a note :P
Just have to look out for kangaroos tank. Nearly totally my car :)
I saw the prick with 5 metres to spare, Martin didn't see him I was going 100 and had to go completely on the other side of the road to miss him by around a foot or two.
Butt clenching moment haha!!
QFT
I would have seen it if it came through the windscreen
Your plugs should not have clogged themselves up that quick. I suggest you give a jez a ring to run some diagonistics.
O2 sensor voltage can be checked with the afore mentioned diagnostics or pull em out and if there fouled like your plugs then there Probarly stuffed.
dear heavenly father. twin turbo be thy power, thy kingdom come, tuning will be done, as in aus as in japan. bring to this day four wheel drive and praise our power figures and forgive thoes with less power than us. keep us safe from the cops and deliver us from the under ground, for the GTR32 33 & 34 for ever and ever amen
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
