S A U__N E W C A S T L E
After you start it by holding the throttle wide open, does it then idle correctly without throttle or does it stall? If not it sounds like one of the injectors might be stuck partly open. You could also drain your oil and check for a heap of fuel in it. If it doesn't idle there is something wrong with the tune (unlikely, because it worked when it was tuned), or something changed on your car like the AAC or cold start valve no longer working correctly. BTW, I know we are a multi-cultural forum now, but "gas" makes no sense as a term for the pedal that opens a petrol engine's throttle, either directly or electronically.
I bought the NZEFI 1000CC injectors with the ballaster resistor delete pack. It started fine for a few days and even drove it to the Tuners dyno and back. Then one day i drove it to work, and on my way out of the office, the car wouldn't start. Unless i put the gas pedal all the way to the floor and then crank the engine over. Called the tuner and we tried a bunch of different settings but trying to figure it out now. Anyone else experience this? Haltech Platninum Pro. https://www.nzefi.com/product/nissan-rb-1000ccmin-top-feed-direct-fit-fuel-injector-kit/
After the windscreen motor from r31 skyline or pintara, located Grafton NSW
I'd do it all again in a heart beat. Well, not all, I'd make some different choices in which mods. But I'd definitely still spend all the money.
Hey y'all, Looking local to USA, for just side skirts and rear bumper or half bumper. Pics for reference below: Top is east bear style rear bumper, bottom is uras style rear half bumper. Side skirts are interchangeable. Thanks y'all!
