Enjoying the sound of an SR is an aquired taste....
Just to recap on the last comment, assuming your understand this is Skylines Australia..... And skylines have RB's which are awesome....
Your SR has as much value as the tampon Pulled from a fat chick in her P
i know wat ur sayn mate and i agree in a sense until a couple of weeks ago when i was at jezas shop and he had a built sr20 in a s13 with a precision turbo make 335kw on 24psi (low boost) :woot: the thing was a animal the owner was lookn to run 37psi high boost.it sounded awesome :yes:
Hey benji,
Has extreme super ultra late braking as per your driving style ever sent you off into a field?
I mean come on how late can you brake with metal on metal brakes??
haha read that this morning and was thinking the same thing....
should add 'to infinity + 1' after it just to be sure :)
Hey benji,
LOL
I havent driven the car since I took it for a drive when I got my full licence (based on advice from everyone).
My driving style always is extreme ultra super late braking.
Front brakes are fine, rear brakes are metal on metal. When I had my drive after I got my full licence I just relied on engine braking by downshifting early... and then quickly pressing the brakes firmly to pull up to a stop.
Wakefield RaceTrack
When I had my trackday on July 25th, The rear brakes became metal on metal in my last session, and naturally I just thought optimistically and assumed I was getting pretty severe brake fade and that my pads were just on the replace indicator (little metal shavings to warn you that your pads need to be replaced).
The rear end felt very unstable and very twitchy as the metal on metal brakes at the rear weren't grabbing evenly, and I really had to manhandle the car to keep it on the track. Goes to show how good the front brakes for the S15 are, considering I was still cannonballing down the straight at about 160-170kmh.
Hey benji,
Link please
Oh and the L/H at work can go f**k himself
Took three hours work off Fridays run cause he thinks I will run out of hours.
Seriously I could do it in 10 hours tops with my eyes shut
Really over the shit at the moment
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
