If anyone's keen, thinking about going for a drive to check out some roads today...
The route from newy is approx 300kms and will take 4-5hrs ha...
Going around gresford, dungog and further north
Just saw this now so probably to late to get a lift in Big Bird
Well back from the mechanics, and the verdict is as he thought, turbo leaking oil into the intake, messing up the AFM, causing it to missfire dump fuel and foul the plugs, fix is replace turbos.
And also with the stock GTR air box and the side pipe, it is used for induction but its blocked off standard, it has 2 pressue clips and the restrictor pops out to give u massive air flow, i can hear my car sucking in more air and its fluttering also now that i have taken it out pics are attached.
Sucks tank, thoughts on turbo??
Probably -7s
https://www.justjap....569&cat=&page=1
2nd hand or if i can get a new set for a good price.
Its something like that or put a set of good stock ones back in it and probably sell it get as much back as i can on it and move on.
Edited by T4NK
T4NK, I have a contact in Japan that you can use to get your parts....
You can get stuff a lottttt cheaper than from JustJap....
For example: I got my Tomei N2 Oversize Oil Pan for $350 incl.postage and JustJap sells them for $800ish.
All the stuff Ive bought has worked out cheaper than Nengun + RHDJapan as well
Probably -7s
That's a lot of coin for turbos
Have you looked at getting yours redone?
http://www.digi-hardware.com/index.html
Might be cheaper with the same result but as the saying goes costs nothing to ask.
Don't sell the car man unless it's to Jarred when he has the coin :)
For once Benji might be onto something here.
First very usefull post I've seen ever from you
Price on some 550cc or higher injectors for a 25NEO please
Oh and have you finished the drive yet Ant?
Hope the car is still in one piece
Was up around Gresford way last week and sections of the road are utter crap.
Apart from the bit between Gresford and Vacy that has a few rises and dips in the road. The truck gets very light in the front end at 100 through that section.
If you went just a bit faster in a car I reckon you could get air easy enough
Found these, talking to the guy atm about shaft play ect, getting some pics and a video of the shafts sent to me since they are in melb, if they are good ill take them i think, 10,000km or less on them
http://www.skylinesa..._1#entry6543765
Edited by T4NK
If you can get a price for me posted that would be great to. thanks :yes:
haha martin 34s are way to over priced for me but thanks for looking out for me bruv
the run was pretty shit but we got good pics of the bird and saw some great scenery, wooten way is our cruise after the next one.
what would you buy tank?? never know it could be great after the turbo and be worth keeping
not sure m8, was considering a TRD chaser or even just a GTT 34 something thats not as expensive to fix when i brake it, cauz i know im going to brake it lmfao
Yea sorry Martin were abit late, we were on the road by 1030...
Roads were very rough, therefore very slow! There was one good section from dungog over to buckets way, but apart from that, wooten was great! Smooth and very wide, and 100kph speed limit and no other cars on the road.
Will hit it up for the next run.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
