http://www.skylinesaustralia.com/forums/topic/414822-r33-gtr-series-2/
god damn i want this!!
mad price!
Rb28, -5 turbos (probs change that), seems like a heaps genuine seller, saying it has a couple dings but there getting fixed before sold.
also, found out today im not being kept on for my apprenticeship but i may get a job for the same company but maintaining the locos that ive built for the past year, better hourly rate, and rolling roster between day and arvo shift with 4 10 hour days with the option to work any friday. a bit keen...
yeah ill find out hopefully this week or early next if i get the job as the email and everything has been sent.
dont think im gunna worry about the mines, the casual blokes at my work are on 40 bucks an hour and thats standard for newy, when you think about the distance and then having to rent somewhere in singleton ill either be living rough or saving less money then working in newy and coming home to emma every night.
plus i doubt id get in a mine cause i dont have family in there :S
http://www.skylinesa...3-gtr-series-2/
mad price!
Saw that. good price....but way down on power for -5's...but it wasn't exactly seeing much boost. Also, don't know where you got the rb28 info from.
.8 sump with baffles??
that not 2.8??
yeah i thought that about boost, would expect 280 atleast
nope just an extended sump. Mine's still a 26 and holds 9L (11L if there's oil in the cooler)
rb26's can suffer from oil starvation. With a combination big G corners, high rpm's and a poor head oil drainage design, the result is that the stock pump can essential empty the sump and thus suck air = no oil for bearings = spun bearing. After market pumps can flow more then 25% higher then stock, so the problem is amplified. The larger sump capacity pretty much eliminates the lack of oil problem and the baffels keep the oil around the pick-up during high-g corners. n1 engines came stock with a higher oil capacity, so nissan was probarly aware of the problem from there racing experince.
ahh i see, fair enough then :P
whats the advantage of a bigger sump??
hey joel hows WA? good to see your still lurking newy :D:D:D
i still check in from time to time :yes: . I'm bored at work and the WA section is dead.
WA's going well. Still haven't found a house yet though...and I'm really missing my tools (their in storage). Hopefully i'll have one by the end of the year and can start to settle in then.
ah right, where are you now then??
id imagine everything to be expensive as!
Work's got me a place in the middle of the city for a few months - it was part of a relocation package. Trouble is, i'm still working up in Port hedland, so i'm never actually in perth to be able to look for houses.
Yeah it's probably about 20%-30% more then newcastle for just about everything. But good city, very social.
I went 4wd on the weekend with a few mates, the old ferroza held up well conwsidering it's completely stock:
wow crazy!!!
newcastle is expensive enough!! cant beleive people buy investment properties in the illawarra compared to a lot of other places in the country!
jesus dude!!!
didnt know the old girl had that in her!!
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
