...waits for informal cruise to be cancelled.
lol just kiddin Benji
Hows the S15 going?
Apparently the brakes dont work :P
Now you just need some NOS....two of the big ones
And Harry, i need em by tonight!
That's not good :wacko:
it's been like a 1000 posts since the last F&F quote...it had to be done :woot:
Good work! Can never have enough F&F quotes!
Did you see the new updates man? You updated yours lately??
ok its on at details are 123 fake street starting at 2500 hours...
hahaha
jokes, all good, all welcome
hahahaha nice one Ant, its a long drive though -
http://www.zillow.com/homedetails/123-Fake-Street-Long-Beach-CA-90802/2120044872_zpid/
yeah...saw your dodgy balancer...lucky you saw it before your crank nose wore out.
No major updates for me. Car's got a massive oil leak from one of the new braided lines and i haven't had time to sort it. Parts wise, i'm hoping to pick up my front pipes, rocker covers and cat from Paul while i'm over east and get them installed while i fix the leak. Then it's going back to the tuners for more BOOOOOOOOST!!!!!!
Nice! When you back again? I think you said it but i forgotz
Hows the S15 going?
LOL, S15 is going well....noticed a couple of pindrops of black oil on the piece of cardboard (which is under engine bay where I park) but meh, I dont know where its coming from so probably nothing to worry about.
Steering feels a little vague but that comes down to the fact it still has the stock suspension setup (with the struts leaking)...
The car definately has a lot of potential though and is an awesome platform.
Also re: brake situation. I left my car outside a mates house in Sydney parked on a downhill slope with my steering wheel pointing slightly to the left (luckily) and I pulled up the handbrake and left the car in neutral (should have put it in reverse). Anyway came out later, and the s15 had probably rolled down the hill about 3-4 metres before mounting a driveway/gutter. Luckily no damage underneath though due to tractor ride height :D
    • Somehow we've reenacted this video completely seriously:
    • Nistune is pretty easy if all you want to do is change the injectors. TIM + latency change will do it. But I am very skeptical your mechanic has actually diagnosed the issue. As others have said flow/function test your injectors.
    • ^This. If you have to do injectors, and you have to buy bigger ones, get the smallest Bosch EV14 based injectors of the correct length that you can. This will be about 500-525cc most likely. The stock ECU (with Nistune) will be fine to run those. Then, use a Nistune. Tune it yourself. If all that you are doing is changing injector size, then you literally only have to change one number to do it, and then maybe some fine tuning of that number. You will not need to touch the fuel or ignition maps at all.
    • I don't know what those pipes are, but I'd say there is a good chance they are old school Japanese tuner because they are equal length and nicely made. Maybe someone like @Rezz who has direct access to japanese history might be able to help. Even so, I'm not sure what inspectors could check it to, they presumably are googling 30 year old japanese stuff same as us.
    • Yep he is an awesome bloke, we work together on that car. You will have fun at the 6hr, Tony doesn't stuff around when he goes racing does pretty well.
