well it's 40deg and i've just spent the the last 2 hours "walking the belts" (lots of steps and steep inclines) at work
I'm stuffed :turned: ...need to get fit
10min break then i'm back out for me :domokun:
Earning the cash and getting fit! You are doing it right!
I work in front of 2 computer monitors all day in AC set to 19.....Are you positively annoyed friend?? LMFA i put u M A D ? and it made it that
Edited by T4NK
lol thats my normal working environment too!!
It's just today my supervisor is busy so i'm taking an auditor around the site...trouble is... its a BIG site (biggest ore shipping terminal in the world).
Nice
Hook a brother up man
I'll walk all friggin day if the money is good
come on joel a couple hours wont kill ya! the boys on the floor do that every day! :P
haha nice one ben
haha lol it actually wasn't that bad...i just wnated to whinge cause it was freekin hot!!!. I've done my time on the floor with the boys...but i must say i'm enjoying the air conditioned office alot more :yes:
anyway, back in perth now for a few days R&R
What's facebook? :-p
It doesn't work on my phone or work laptop...so sau become my only avenue to post random stuff that no one wants to know about while I'm at work lol
Edited by wedge_r34gtr
f**kin oath Chris!!!!
Did you sing out get your tits out????
On another note,
TEAM YELLLLLLLLOOOOOOOWWWWWWWW!!!!!
HAHA, bit keen ay.. yellow red or blue. (If I have swayed to an evo, well see)
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
