I forgot about 3 mainly cause of the big turd that it is
EDIT. Bout the only good bit of that movie was the stuck up blonde getting injured at the start
Oh and trying to drift a FWD Lancer on the docks with expert commentary from the old fisherman
The dirty blond was pretty funny,
I thought they just droped the front shaft out of a ralliart lancer?
Edited by wedge_r34gtr
pretty epensive if its at home? is it 415 or 240?
Either way, I'd say they would have to run a seperate line to the transformer for 3 phase.
Sounds sucky :/ might give that a miss by the sounds of it...
do you already have 3 phase in your switchboard??
do you have rewireable fuses or circuit breakers in your switch board?
if you picture digging a trench from your switchboard to your garage, is it a easy path?
why do you NEED three phase?
these questions answer yours :)
a mate of mine done a uni project on converting single phase to 3 phase power last year.
Uni projects are generally based on something that has already been done so there might be an off the shelf unit that does it
ah yes, keep forgetting your a sparky
I still need to dig that trench anyway as there is NO power there yet... So that's not an issue!!
The hoist I want can be single phase if it needs as they are cheap enough...
if there were no rules and you dug the trench i could do it in a couple hours for ya hah. but im not a tradesman etc etc etc
Well hurry up and get your trade :P
How many wires from the pole to the house?
Is the tyre machine cheap enough as in a couple of hundred or is it more than that?
Also be very careful what type of arm it has as some can move when taking off or fitting tyres and can scratch rims
Also a good idea to have one or two 15 amp outlets in a garage as well for welders or compressers if needed
EDIT just my 2c worth
Edited by m.j.h
ahh but you overlook the etc etc etc haha.
i get my trade in december then ill look into getting everything i need to do it for you!
At the rate I work it'll probably take that long to dig the trench :laugh:
Yeah hopefully I can keep chipping away at debts and then be able to afford to wire up the shed and ONE day get a hoist so it makes it easier to work on our cars :D
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
