^^^possibly - it has silly big injectors (2200), wasn't warmed up and hadn't been started in ~10days. This was my intially thought and i'm hoping it's this.
Plug's and coils are good - i wouldn't expect all six coils to fail simultaneously.
I'm going to go though all the relays, fuses, wiring etc either this arvo or tomorrow and see if i can find anything.
Mine has 2000's but doesnt have a proper tune yet.... Have had a failed start once or twice but if yours is tuned you shouldnt have the issue....
It's really only had a basic tune - but, your right it should still be running correctly. I'm going back to the tuner on Friday afternoon to check some things, so i'll get him to make sure the cold start map is right.
I'd say that's your issue.
They are big ass injectors. Even if the cranking enrichment is a little bit out, it's going to be dumping fuel.
Simple fix. Let it warm before turning it off, just a couple of mins should do it.
Good to hear :)
You look to have the same traction issues as me.....
Would not do anything silly on the streets man! Tracy is not to be messed with!
And yeah traction is not something available in the first couple of gears!
Has anyone had a diff centre put in there housing done by someone locally that they would recommend?
I was looking at possibly taking it to difftrans unless someone can recommend a different workshop
There's reportedly a gearbox/diff place in Steel river that's meant to be top notch - worked on quite a few high end cars. (name eludes me sorry)
Otherwise i higly recommend from first hand experience Award gearbox & Diff in Sydney - Terry and Trish will look after you and are fairly competitively priced.
That is DIFFTRANS man!! And Aaron gets my approval as he has been nothing but helpful too me!
Also heard good things about Award, dont they have those awesome business cards??
yes thats the one!
Terry was out of cards when i picked my gearbox up so i don't know unfortunatly :-(
Edited by wedge_r34gtr
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
